Opinion Of Work In Progress - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-04-2011, 06:02 PM   #1
Opinion of work in progress
Contractor is doing a tear off then re-roofing and installing aluminum fascia & soffit. I only do electrical and some smaller home projects so my question is does this look correct? The shingles look lumpy to me but I'm told they will lay flat in 1-2 weeks after warm weather (BS?).
1dog1taco is offline   Reply With Quote
Old 10-04-2011, 06:41 PM   #2
MJW
The shingles will lay flat with some time and heat. It won't take much. We have done roofs in the middle of winter and they lay down just fine with some sun.
MJW is offline   Reply With Quote
Old 10-04-2011, 07:12 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
That pipe collar is done wrong. The bottom half is supposed to be on top of the shingles. Not under them.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
MJW (10-04-2011)
Old 10-04-2011, 07:18 PM   #4
Framing Contractor
Rewards Points: 120
Looks like the collar of the vent may be too.
sixeightten is offline   Reply With Quote
Old 10-04-2011, 07:45 PM   #5
MJW
Didn't catch that. I seem to skip the obvious because anyone calling themselves a contractor should know how to install a pipe boot.
Old 10-04-2011, 10:26 PM   #6
More photos. I'll have a friend of a co-worker who does roofing stop by to give it look in person later this week too. Thanks for your feedback.
Opinion of work in progress-img_1701.jpg   Opinion of work in progress-img_1709.jpg
Old 10-04-2011, 10:34 PM   #7
ParagonEx's Avatar
Rewards Points: 150
Man, I cannot stand guys who do their valleys that way.
ParagonEx is offline   Reply With Quote
Old 10-05-2011, 06:09 AM   #8
kwikfishron's Avatar
Rewards Points: 760
Since I see no vents at the ridge I guessing your not going to open up the soffits and add vents at the eves while you have the chance either.
It’s hard for me to believe that a contractor with any level of experience would not have told you that vents are needed and now is the time to do it.
kwikfishron is online now   Reply With Quote
Old 10-05-2011, 08:15 AM   #9
They are cutting holes and installing vented soffits.
Old 10-05-2011, 08:57 AM   #10
I zoomed in and it appears the collar bottom is over the shingles. Here are some additional photos.
(from wife) The images posted here are so disappointing. If we could see the inconsistencies from the ground, it's scary to see them close up. I am sad that the crown molding was taken off, especially since it uncovered the unpainted section of the fascia. BTW, we are getting new siding as well, I hope that experience is better.
Old 10-05-2011, 12:07 PM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,184
Not a fan of the work product there at all.
The Following User Says Thank You to Windows on Wash For This Useful Post:
1dog1taco (10-05-2011)
Old 10-05-2011, 02:03 PM   #12
Here is what it used to look like.
The Vents were on top. -Attaching images of the roof as it was. I hope the vents were re-installed. I did see them stack a bunch on the driveway. House on left is ours, house on right shows the roof line better. Strange how the vents are only on 1 side. (?) Wishing they would have used the type of venting system that hides it all under the peaks.
Old 10-05-2011, 02:31 PM   #13
RFN-4A-LVN
Roofmaster417's Avatar
Amongst other things.,.,who was the genius that chose the white drip edge?.,.,and what is the deal with the porch ven?
Roofmaster417 is offline   Reply With Quote
Old 10-05-2011, 02:44 PM   #14
Rewards Points: 83
Our building code would want a vent there as well.
bcdemon is offline   Reply With Quote
Old 10-05-2011, 04:43 PM   #15
Pro Slate Roofer
tinner666's Avatar
"I zoomed in and it appears the collar bottom is over the shingles."
Now that is something to see! The lower flange of a PC gives 4-5" of protection from blown rain. Why on earth would some idiot cut the flange off????? It's there for a reason just like 'termination flashing' which the bottom flange is! Now, you have no protection there.
Tags
contractors , roofing , shingles
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 11:53 AM
J-B Weld to Mount Metal Box HooKooDooKu Electrical 161 02-04-2010 11:12 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
