"opening" Roof... How? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-07-2012, 11:57 AM   #1
Thumb Banger
Rewards Points: 20
"opening" roof... how?
Ok. I've been working on replacing some rotted studs and sheathing in the back of my house where I took down an old block chimney and have reached the roof. The ends of two rafters are soft, besides which the fellow who built the chimney that caused all this damage 35 years ago cut the tails of these two rafters off. I want to repair these by sistering a couple 2X in there, but I have to open the roof to get there.
Do I just snap a couple lines along nearby healthy rafters and cut through the shingles and sheathing? I only need to go up about 4 feet. The shingles are Owens Corning Duration and there are no old layers underneath.
scroff is offline   Reply With Quote
Old 08-07-2012, 12:05 PM   #2
kwikfishron's Avatar
Rewards Points: 576
You’re better off carefully removing and stepping back the roofing first then make your cuts. The roofing has to come off anyway, you might as well save a saw blade.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
scroff (08-07-2012)
Old 08-07-2012, 12:32 PM   #3
Thumb Banger
Rewards Points: 20
Originally Posted by kwikfishron View Post
You’re better carefully removing and stepping back the roofing first then make your cuts. The roofing has to come off anyway, you might as well save a saw blade.
It's never easy is it?
These things stick like glue. Heading up to the roof with my trusty flatbar.
Old 08-07-2012, 12:37 PM   #4
Rewards Points: 576
Early in the day when the shingles are cool is your best bet for success.
scroff (08-07-2012)
Old 08-07-2012, 12:42 PM   #5
Thumb Banger
Rewards Points: 20
I owe you for that one. Now I can stay off the roof for the rest of the day and go up tomorrow morning. I can tell my wife you said so
Old 08-07-2012, 02:48 PM   #6
Rewards Points: 1,580
Just make sure it isn't slippery from dew in addition to your other precautions.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
scroff (08-07-2012)
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 01:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
