Open Vs Closed Valley - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-19-2010, 03:45 AM   #1
Rewards Points: 180
open vs closed valley
I tore off most of the old roof and getting ready for the new... it was closed valley 3 tab. I'm going with either Timber dim or CO dim. I don't know if I want to bother with the cement required with open valley, but the dim is thicker than 3 tab:
Is it harder to do a closed valley with dim shingles? I'm in Sacramento, CA and it'll be mid 80's when I do the roof. I have a heat gun, will that help to get them to bend without damage?
Thanks... KarlJay.
KarlJay is offline   Reply With Quote
Old 09-19-2010, 06:58 AM   #2
Residential Roofer
Slyfox's Avatar
30 & 40 yr can be weaved or closed cut, lifers should not be.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Need input on this open valley technique jogr Roofing/Siding 12 11-01-2011 06:49 AM
Fresh air intake damper - Open or Closed? dtran HVAC 7 01-06-2009 05:30 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
garage door open light deck hand Electrical 3 01-22-2008 08:29 AM
Open valley flashing question steve1234 Roofing/Siding 2 10-01-2007 12:19 PM
