Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 11-05-2011, 11:44 PM   #1
Open Gable Porch Roof
I am adding walls and a gable roof to an existing deck which is attached to the end of a house. The roof is an extension of the gable roof on the house. The deck and new roof extend 11 feet from the house. The width of the deck is 20 feet. The sides will be 10' high 2x4's on 16" centers. The rafters will be 2x8's.
Do I need a center post on the open gable end of the porch? I would like to leave it open from sidewall to sidewall.
Thanks.
Lakeowner is offline   Reply With Quote
Old 11-06-2011, 12:30 AM   #2
ParagonEx's Avatar
Thanks.
Sounds like it.
What did the inspector say when looking at the plans?
ParagonEx is offline   Reply With Quote
Old 11-06-2011, 10:27 PM   #3
Rural area. No inspector, no code.
Old 11-06-2011, 10:40 PM   #4
Pro Slate Roofer
tinner666's Avatar
Do I need a center post on the open gable end of the porch? By definition, that's a non-support area, so you should be OK. If the top is to be closed, be sure to use a cross beam, wall tie that will not sag.
Frank
tinner666 is offline   Reply With Quote
Help - shell to screen an open porch - Mobile Home mgnet Remodeling 4 05-29-2012 10:23 AM
Converting a closed porch to an open porch taycop Building & Construction 2 07-28-2011 11:13 AM
Cross Gable roof porch addition ehowardal21 Building & Construction 1 09-03-2009 05:10 PM
Want to add a Gable roof over Deck dtex Carpentry 1 04-23-2009 09:38 AM
Building a Porch Roof Engus Building & Construction 1 04-06-2009 09:43 PM
