Open-end Gable Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-15-2012, 06:12 PM   #1
open-end gable roof
Adding a open-end gable roof to an existing L-shaped brick home at a 45-degree angle tangent to the inside corner of building. The existing 2 roofs have rafters and ceiling joists that are perpendicular. The ridge will tie into the second story top plate at the same inside corner and it's height is as the other ridges. All roofs have a 3/12 pitch. Are the valleys sufficient enough or do I need a roof beam to span the hypotenuse (open-end)? Use collar ties instead? Trying to achieve a cathedral ceiling appearance.
kevinjentsch is offline   Reply With Quote
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 08:31 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Gable Roof Span Gandalf Building & Construction 2 04-29-2010 09:45 PM
Insulation in roof rafters at the gable end nofx1981 Roofing/Siding 5 03-09-2010 03:21 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
