One Piece Of Shingle Was Torn Off By The Heavy Wind - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-04-2014, 09:53 PM   #1
One piece of shingle was torn off by the heavy wind
A piece of one story house roof shingle was torn off by the heavy wind. The course below is still good. It seems needing a new piece of shingle to be nailed and glued down to the course below. Is it correct? If I ask the roofer to repair it, how much will be reasonable for this kind of job? See the picture here. Thank you.
compiler is offline   Reply With Quote
Old 01-04-2014, 09:56 PM   #2
Rewards Points: 6,652
If just one tab, you should be fine until it warms up enough to slip out that broken shingle, replace with a spare if you have one. If it was the whole shingle, OSB, Plywood or Pine boards are showing, you need to cover that side of the roof until it can be fixed.
Old 01-04-2014, 10:06 PM   #3
Rewards Points: 12,878
No pictures came up.
Why not fix it yourself?
Got some leftover shingles? If not that's the hardest part of the job, finding matching shingles.
Only need an extension ladder, hammer, flat bar, a shingle and about 1 hours or less time to do the whole job.
You would have to call some local roofers or handy men for prices.
You did not add your location to your profile so hard to even make a guess on prices.
Asking prices on the net is just going to get guesses that are not going to you much good.
Old 01-04-2014, 11:31 PM   #4
You should click on the word "here." It will display the picture. The job should be pretty easy but the roof slope is 45 degree and very slippy because of the sand. It has risky to climb on the roof. Do you have any good ideas to climb on the roof such as the special shoes etc, by the way?
Old 01-05-2014, 12:09 AM   #5
You use two ladders in your case.
One with ladder hooks that sit over the top of the peak of the roof.
Looks like you have some odd metric shingles.
Get some more prices. I guess there going to come close in price.
There all going to have to spend time hunting down a matching shingle.
There all going to have to buy a bundle of shingles.
There all going to need two ladders.
There all going to have to stop working on another job to come fix that one shingle.
Make sure who ever shows up leaves the leftover shingles.
Old 01-05-2014, 12:37 AM   #6
By the way, is it okay if I leave the problem there because the base wood does not show up?
Old 01-05-2014, 06:09 AM   #7
roofermann's Avatar
Rewards Points: 399
Yes, this should be ok till we get some warmer (40f +) weather, Good luck!
roofermann is online now   Reply With Quote
The Following 2 Users Say Thank You to roofermann For This Useful Post:
oh'mike (01-05-2014), Windows on Wash (01-05-2014)
Old 01-05-2014, 02:34 PM   #8
Ok,I may try to replace this shingle by myself. Is it correct to nail and glue down a new piece of shingle or glue is not necessary? If the glue is necessary, what kind of the glue is good for the shingle adhesive?
Old 01-05-2014, 05:25 PM   #9
It's not glue.
http://www.homedepot.com/s/roof%2520caulking?NCNI-5
I would not bother with it but if it makes you feel better it's not going to hurt.
Old 01-06-2014, 08:32 AM   #10
Rewards Points: 83
If your roof is a 45 degree pitch as you say, that equals a 12/12 pitch, so STAY OFF IT. Hire a professional to do this or risk a fatal fall, your choice.
bcdemon is offline   Reply With Quote
Tags
repair damaged shingles
wind storm knocks off shingle on steep peak sandyscamper Roofing/Siding 4 02-19-2013 07:50 PM
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 10:05 AM
hip shingle torn and roof nail exposure timcsi Roofing/Siding 1 09-29-2010 11:09 AM
need advice of choosing the proper roofing shingle product nc_yella Roofing/Siding 10 11-19-2008 04:49 PM
