One-man Re-roof Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-22-2013, 06:41 PM   #1
Hi all. I've roofed 3 new homes before, but never a reroof. I'm concerned with how much time the tear off will take, doing it by myself. It's an all hip two-story with one-story garage, all 4/12 pitch. Currently has old 30 year asphalt shingles (one layer only), and there's roughly 26 squares in total. Each hip section is roughly 3-4 squares each. I plan on tearing off and putting underlayment down a section at a time. Any guesses on how long tear-off/underlayment will take me for each section? It rains a lot here, and it's often unpredictable, so that's my main concern. Mahalo,
Jason
jkauai is offline   Reply With Quote
Old 10-22-2013, 07:05 PM   #2
Metal Roofing
Rewards Points: 600
I would farm that part out even if it were my own house. That will take you a long time if your solo.
AndyWRS is offline   Reply With Quote
Old 10-22-2013, 07:08 PM   #3
Thanks for the reply. I would, but you're limited on Kaua'i, and no contractor wants just a tear-off job right now..."we're busy".
Old 10-22-2013, 07:29 PM   #4
Metal Roofing
Rewards Points: 600
If your able to drop it from the roof into a truck bed you could do it in a day. It is the dropping it on the ground and having to pick it back up to put into a truck thats gonna add to your 1 day. If thats the case you would need a weekend.
Its an easy pitch and its not very big so you have that going for you...oh yeah and its one layer. If you can drop it into a truck bed directly it should not be a huge deal. Just a lot more labor if your picking it off the ground, we call that "double handle" and the crew gets paid additional $.
The Following User Says Thank You to AndyWRS For This Useful Post:
jkauai (10-22-2013)
Old 10-22-2013, 07:31 PM   #5
Gymschu's Avatar
Rewards Points: 822
Did this very thing on my own house. It is difficult at best. Doing a section at a time can be disastrous. You will always have to cover the hip to make it water tight before tackling the next section not to mention you will have to walk on new shingles to tear off the next section. In the end, to be honest, it would have cost me less dollars and less aggravation to have hired it out. Really. By the time I bought all the tools, spent evenings and weekends of my valuable time, bought shingles that cost me more than it costs a contractor, getting rid of the shingles in the landfill.......well, you get the picture. You really need to keep looking for a contractor or at least wait til they are "not busy."
The Following User Says Thank You to Gymschu For This Useful Post:
joecaption (10-22-2013)
Old 10-22-2013, 07:44 PM   #6
Thanks for the replies. I have all the tools and know-how, and I'm not shingling each section as I go, just underlayment. I'm using a Polyglass self-adhering underlayment that's good for 30 days exposed.
Andy, I think I'll give myself two days to get through the tear-off underlayment. Thanks for the thoughts. Definitely putting tarps on the ground for cleanup.
The Following User Says Thank You to jkauai For This Useful Post:
Gymschu (10-23-2013)
Old 10-22-2013, 07:52 PM   #7
Davejss's Avatar
Rewards Points: 772
If you're just doing a 3-4 square section at a time you shouldn't have any trouble. You can strip one layer in no time and then get your underlayment down pretty quick.
Shingling 4 squares shouldn't take you more than a couple of hours.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
jkauai (10-22-2013)
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 01:30 PM
Another roof ventilation question Jim F Roofing/Siding 9 05-13-2010 07:51 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
roof leak question joshm Roofing/Siding 23 04-04-2008 10:44 PM
