Old, Spaced Roof Boards Dangerous, Bad, A Deal Breaker? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-02-2009, 05:42 AM   #1
Rewards Points: 49
Old, spaced roof boards dangerous, bad, a deal breaker?
I'm buying an old duplex. The roof must have once been wood because the decking is old boards with even spacing between then, say an inch for every seven inches or more of board. The inspector thought there must be ply decking over the top of these boards but, alas, there isn't. The inspector, true to their reputation of half-assing it, did not so much as tap the exposed paper because, when I did, it was clear there was nothing more than paper and shingles. To be sure I screwed a screw driving through it.
So, is this a deal breaker? Are these kinds of roofs unsafe or otherwise "bad" for any particular reason?
Also, should I ask the inspector for my money back?
jrdamien is offline   Reply With Quote
Old 01-02-2009, 07:45 AM   #2
A cheap 3tab shingle might sag into a 1" gap, but it should be be a problem with a good dimensional shingle. What is the roof pitch. The greater the pitch, the less the problem, regardless of the shingle.
Old 01-06-2009, 07:56 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
and don`t go putting screws thru from underneath,that creates problems--should have had plywood installed over it,but I`ve seen them your way also with no problems
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
New 1yr Townhome with Leaking Roof! sijunk Roofing/Siding 9 08-08-2008 04:50 PM
