Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-10-2012, 03:55 PM   #1
Question
old skylight leaking
this skylight roof housing leaks mildly when it rains really hard or there is a lot of snow melting.
any idea what i should do to waterproof it again? looks like hot tar seal around the glass panels. the housing body looks like sheetmetal covered in some bitumenous coating
thanks
Old 06-10-2012, 09:44 PM   #2
Remove and replace with new. That thing has had it's day.
shazapple is offline   Reply With Quote
The Following 2 Users Say Thank You to shazapple For This Useful Post:
amakarevic (06-10-2012), Gymschu (06-11-2012)
Old 06-11-2012, 07:22 AM   #3
Exterior Construction
Windows on Wash's Avatar
+1
I am not sure I trust the curb in either or your threads either.
Old 06-11-2012, 12:24 PM   #4
that curb is fine. do you have any idea about what i should do there? if so, i would appreciate some instruction (please use that thread).
thanks
Old 06-11-2012, 01:12 PM   #5
Pro Slate Roofer
tinner666's Avatar
Peel all the crap away until you get to the metal frame.
Just gently disa\emble the frames and note how they are made and shaped.
The end frames, bottom frames and top ridge frame are all you need to remake.
The glass slides up the two side channels and under the ridge metal.
The bottom frame has the drains and locking tabs to hold the glass in.
You can make this out of heavy aluminum, heavy galvanized or prepainted steel.
A thin piece of weather strip goes under the glass in the channels.
No caulk should be necessary, but it can be put in under the ridge, in the channel, and under the metal side caps, in the channels, at the edge of the glass. None at the bottom. No caulk will be visible.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Tom Struble (06-17-2012)
Old 06-11-2012, 02:21 PM   #6
Pro Slate Roofer
tinner666's Avatar
BTW, any glass shop worth it's salt should be able to make the replacement parts necessary and do the reinstallation.
Frank
Old 06-15-2012, 09:58 AM   #7
that thing has been patched so much that theres not much left of the glass area. the for sure way is to take it apart and rebuild it so you have something clean to seal to.
hotrod351 is offline   Reply With Quote
Tags
skylight
Dome skylight leaking AAK Roofing 1 10-08-2010 06:47 PM
leaking skylight? cbzdel Roofing 2 06-03-2010 07:09 PM
Help! Our skylight is leaking and the sky is falling! Puzzledone Roofing 14 06-08-2008 08:10 PM
Leaking fixed skylight mt232 Building & Construction 5 11-23-2007 11:12 PM
Skylight leaking advice needed!Thanks Beeper29x Roofing 12 10-04-2005 09:53 PM
