Old Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-11-2012, 10:54 AM   #1
Rewards Points: 48
Old shingles
I have almost a full bundle of shingles that has been in my shed for about 13 years. Is there any reason why these should not be used. It would save me a bundle[literally and figuratively].
one eye guy is offline   Reply With Quote
Old 08-11-2012, 11:20 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Theoretically, they might be okay if they were stored out of the elements and not cooked by the sun.
What are you using them for? Might be a good idea to hand seal them as a precautionary measure.
Old 08-11-2012, 01:02 PM   #3
Rewards Points: 48
I would be using them to reroof the shed they have been stored in all these years. They were left over when I had the shed built.
When you say hand seal them, what do you use to do that? I'm very much an amateur.
Old 08-11-2012, 03:04 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,728
Ayuh,.... Just add abit of black tar on the underside bottom of the shingles, so's the wind don't lift 'em...
It'll seal the upper to the lower shingles...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
one eye guy (08-12-2012)
Old 08-12-2012, 04:18 PM   #5
Rewards Points: 48
Thanks Bondo. Appreciate the help.
Old 08-24-2012, 07:24 AM   #6
Rewards Points: 850
seeing as there only going to save you about $25.00 id say no. its a bit of work installing them to find out they will fail, and do all this just to save $25.00 isnt worth it.
hotrod351 is offline   Reply With Quote
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
New Shingles: Defective Shingles or Bad Install? TTZip Roofing/Siding 9 04-30-2013 01:03 AM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 03:42 PM
