Old Roof Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-16-2006, 01:31 PM   #1
old roof problem
Turning a barn into an office; roof has waves in it and trying to figure our how to level it out; about a 4/12 pitch; 1/2 plywood decked over old 2x6 rafters kickers holding up from two interior support wall lines.
About a 16' run one direction with support wall in between low side and the ridge; a 20' run down back side with couple of support wall.
Old asphault shingles have been removed and now down to exposed decking.
Interior floor line not even level enough to work from.
Any comments really appreciated.
Not sure how to go about leveling out the sags and humps;
griffithj is offline   Reply With Quote
Old 07-16-2006, 03:00 PM   #2
Have done this many times. The easiest and cheapest way is to get a bottle jack inside and jack up the low spots. Then reinforce it and resheath it. After that start the roofing and use a laminate shingle to hide the small bows. They don't always come out perfect, but it helps alot if you take your time. If this doesn't seem to be working you can shim the roof on the outside and resheath it , then shingle. barns can be tough with the old hard wood.
MJW is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
flat epdm roof problem larry42 Roofing/Siding 5 04-28-2007 10:03 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
garage roof problem ERIK2173 Roofing/Siding 3 11-03-2005 07:44 AM
