Old House, Hot Attic, One Window - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-20-2011, 06:05 PM   #1
Old house, hot attic, one window
Hi guys, my first post here. I have a small attic, maybe 4x8x12 w/a slanted roof. The rest of the house has a flat roof, this part is tiled. It's pretty well insulated now, but still gets pretty hot. I want to vent the hot air using the small window that 's up there. After reading some of the posts, I want to make sure I'm not creating any add'l problems for myself.
I bought an attic fan that can vent 2000 cfm and I bought the overpriced gable vent shutters as the guy said the stationary gable vents weren't ideal for use with an attic fan. Since it's an original window and opens out, how can I do this without removing the window?
Will I need another opening to outside for cross ventilation or is that not an issue to be concerned with? The attic is pretty sealed up (as much as an old house can be) otherwise
I was going to have a whirlybird installed, meaning a hole would have to be cut in the roof but this seemed to be a cheaper and more energy efficient alternative.
But it seems like with the vents installed I wouldn't be able to close the window once it got cool. I'm in Delaware so June-AUgust, pretty warm. Rest of the time, cool enough.
The window is vertical so if I'm going to use an attic fan, I need to keep it closed when it rains, of course.
Am I missing any details? Is this doable or
Thanks!
Chuckw is offline   Reply With Quote
Old 06-20-2011, 07:00 PM   #2
DIY staff
Rewards Points: 7,174
Got a picture?
Old 06-20-2011, 07:28 PM   #3
A picture would help! I will get one and attach it. This is for Delaware. I need to finish setting things up, just signed up today.
Old 06-20-2011, 07:46 PM   #4
DIY staff
is the attic open and unfinished?
Any other ventilation besides the window?
Old 06-20-2011, 10:21 PM   #5
Yes, the attic is unfinished, but well insulated. There is no other ventilation except some small gaps here & there from it being an old house. If you mean by open that there isn't anything stored in there, it's mostly open.
Old 06-21-2011, 05:53 AM   #6
DIY staff
The fan will help but you need some incoming air --attics typically have soffit vents to admit air from below--then a vent or fan near the top to cause convection.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
New custom house, concerns/problems. pretzels Building & Construction 15 04-16-2011 01:17 PM
How to fix a house window that falls out? Mateo1041 General DIY Discussions 7 11-16-2010 10:11 PM
Installing new attic insulation in old house Upnya Building & Construction 13 11-04-2010 07:14 AM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 11:35 AM
