Old Foam Roof Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-15-2011, 12:55 PM   #1
I have an existing polyurethane roof that is covered with a coating to reflect the sunrays. Through the years it has bubbled up and leaked. In the past we have cut the bubble, drained the water and covered with NP1 caulk. Then applied a polyurethane foam over the top to seal it. This has worked in the past but now we have one spot leaking again. What would be the best way to repair this without having to replace the whole roof at this time? What would work and stop the leaking and keep it from growing into a bigger problem.
Should we use EPDM or TPO or something else? If we use these mentioned products would we need to put fiberboard underneath or Invincible board? Also, what would we use for the seams?
Any help and suggestions would be greatly appreciated.
nkpatel is offline   Reply With Quote
Old 06-16-2011, 09:15 AM   #2
when cutting bubble/draining the water, did you notice if the foam itself was soaked? once it gets soaked and bubbled out, odds are good that its shot - at least for that section. As far as patching over an isolated bad section with some epdm - it sounds possible - and save a heap of $$ too.
But dont get your hopes up too much just yet. How about some pics and more details of the kind of roof you have - ie: layers, decking type, insulation, vents etc.
rodeo is offline   Reply With Quote
Is my roof going to start leaking soon? smithers76 Roofing/Siding 16 09-04-2010 06:10 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
Roof Tiles Leaking SWD76S Roofing/Siding 2 06-16-2008 09:43 AM
Warmer temps and now my roof is leaking nick13 Roofing/Siding 24 03-06-2007 12:56 PM
