Old Dryer Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-03-2014, 10:20 AM   #1
old dryer vent
hi guys,
not sure if this is the right place to post this but... im redoing my kitchen and my laundry room is moving locations as well and the old dryer vent, vents out the side of the siding ... just wondering what is my best bet for patching that hole and sealing it up tight? the siding is aluminum, its on the side of the house that isnt used for anything ... gas meter and A/C is there so its more of an issue of stopping the air and maybe wildlife from getting in vs needing to look great
thanks
Click4chips is offline   Reply With Quote
Old 04-03-2014, 11:26 AM   #2
Rewards Points: 14,306
Aluminum siding is near impossible to just remove a center section to replace.
If you could even find a new piece with the same exposure it could be cut and slide in under the piece above and held in place with some silicone and a couple of trim nails.
Old 04-03-2014, 11:48 AM   #3
ya that makes sense any idea what to use for the hole its self... insulation maybe? spray foam?
Old 04-03-2014, 06:29 PM   #4
Going to have to cut the sheetrock on the inside alongside the studs, may as well make it a nice square hole.
Add fiberglass insulation, then install new drywall, tape and mud.
Old 04-03-2014, 09:34 PM   #5
Registered User
Rewards Points: 526
And don't forget the required poly....under the drywall. IMO, install the termination hood without the ducting and seal the flap shut- no siding to patch.
Gary
Old 04-03-2014, 09:39 PM   #6
my old dryer vent runs between my floor joist out of the house... so theres no dry wall or any thing
Old 04-04-2014, 09:30 PM   #7
Registered User
Rewards Points: 526
Great! Just canned foam inside the hole and shut the hood flap while foam is wet to air/bug seal it closed- no siding to match, people expect to see vents on walls...
Gary
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 07:55 PM
How far to run dryer vent? bigmark77 HVAC 9 12-04-2011 12:08 PM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 06:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
