OK To Put Ridge Vent On Garage - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-08-2010, 10:48 AM   #1
OK to put ridge vent on garage
Is it ok to put ridge vents over the garage? It's an open garage from the inside.
amdspitfire is offline   Reply With Quote
Old 09-08-2010, 03:42 PM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
no problem putting in the vents. their purpose is to circulate the air away from the decking of the roof that overheats the shingles causing premature wear. with the garage being open below, it isn't as big as a concern as a closed attic space would be but it won't hurt and adds appeal and dimension on the outside.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 09-09-2010, 06:00 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Only if you don't need to heat it occasionally.
seeyou is offline   Reply With Quote
Old 09-09-2010, 09:06 PM   #4
coldest it gets around here is 30 degrees once or twice a year in the middle of the night during the winter
ridge vent w/ roof louvres? byocum Roofing/Siding 3 08-31-2009 06:17 PM
Ridge Vent opinions steel1 Roofing/Siding 1 10-16-2008 06:11 AM
best ridge vent? ponch37300 Roofing/Siding 4 07-23-2008 08:00 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
