Odd Roofing Seaming Iron - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-15-2012, 04:39 AM   #1
Does anyone know how this tool gets used? I've searched all over, and any video/article describing standing seam roofing shows a regular double seamer, not this tool, yet this appears to be the only type of seamer that was used by roofers here.
I've ordered from eBay a regular double seaming iron from Germany, since this is the only kind of seamer that is sold here in Slovakia.
freedomlives is offline   Reply With Quote
Old 08-15-2012, 08:00 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,286
Paging Tinner.....
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (08-15-2012)
Old 08-15-2012, 12:19 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Haven't seen one of those. It may be made for working lead, or more likely, batten seams.
tinner666 is offline   Reply With Quote
Old 08-15-2012, 12:39 PM   #4
Rewards Points: 13,472
http://www.stortz.com/catalog.asp?pr...showprevnext=1
Old 08-15-2012, 12:44 PM   #5
Pro Slate Roofer
tinner666's Avatar
Interesting. Not sure if I've ever needed one and improvised instead. No recollection at all.
I was thinking it may be helpful for forming the eave edges when folding 180, but I use a 1/2" flatbar, about 4" by 3". I have a handful of different size flatbar for those apps. Some 6" x 10"x 1/2", and larger.
Old 08-15-2012, 01:15 PM   #6
Could it be used for connecting several sheets together with flat seams? Of the many standing seam roofs I drive by around here, I've only seen one whose pans aren't composed of meter long sections flat seamed together.
But then, if this was your only seaming iron, how would you do a double lock seam?
I've spent almost the past month intensely studying doing standing seam roofing, and it looks straightforward, though labor intensive. But when I've talked to some neighbors and my inlaws about doing it myself, they think I'm crazy. Only one cousin of my wife (a carpenter) thought it was doable when I clarified that I would be buying rolls of sheet metal and cutting them to length.
Old 08-15-2012, 02:56 PM   #7
Pro Slate Roofer
tinner666's Avatar
"But then, if this was your only seaming iron, how would you do a double lock seam?" Good question.
I'd be forced to bend, which I often do, the first bend the first fold 80 with my S-3 hand seamer by Malco. Don't buy the 3" straight seamers! They're extremely limited in what they'll do and the S-3 will do all that and more, so to speak.
Manufacture History Roofmaster417 Roofing/Siding 6 02-23-2012 02:40 AM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 10:39 AM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Cutting roofing iron Niff Roofing/Siding 2 11-29-2008 06:33 PM
