Novice Roofer - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-02-2013, 07:17 AM   #1
PoleCat's Avatar
Rewards Points: 1,646
Novice roofer
Fishing for advice on installing shingles. I have never done this yet so pointers are welcome. I have a coil nailer and the instructions that Owen Corning supplied so I am not completely in the dark. My biggest impediment is I will be working alone.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-02-2013, 07:57 AM   #2
Rewards Points: 13,446
How many square are you talking about? How steep and how high is the roof?
Old 08-02-2013, 08:02 AM   #3
PoleCat's Avatar
880sqft. 5:12 pitch. 12 feet to the ground. 3 peaks 2 valleys
Old 08-02-2013, 08:13 AM   #4
Got a picture of the building?
How do you plan on hauling away the old shingles?
A few tips, lay tarps over any shrubs, railings or decking. Mow the grass before working on the shingles so it's easier to rake up and use a magnet to pick up the nails.
Lay a trap where the shingles are going to fall on the ground if you do not have a dump trailer to drop them in.
If you have to use a pick up to haul the shingle away line the bed with a big enough tarp it can cover the whole bed and go up over the back window and roof. That way there's not going to be any black marks on the truck and the tarp can be flipped back over the load so nothing fly's out.
If possible strip the roof, install the new paper and Storm and ice shield then have the shingles roof top delivered. Lifting up 75 lb. bundles on a ladder gets old real quick.
Old 08-02-2013, 08:17 AM   #5
Get yourself a nice shingle shovel like this.
http://www.bing.com/shopping/bully-t...M=ENCA&lppc=16
Make sure to add drip edging on all sides of the roof if there is none.
Old 08-02-2013, 08:21 AM   #6
PoleCat's Avatar
The old roof is already on the ground and mostly in a dumpster. I have to go out and finish that up here in a bit. The entire roof is already covered in ice guard and water tight. The shingles are on a skid in the back yard.
Dutch Gable
Old 08-02-2013, 08:34 AM   #7
Going to have to come up with a split seal for that power pole.
No box store is going to have it. Start looking for a real shingle supply company. May even have to order it on line.
Old 08-02-2013, 09:25 AM   #8
Rewards Points: 1,016
Hire a day laborer to help.
Delivered to the roof is sooo much better than on a skid in the ground. Any chance to get this done?
____________
Vince
Old 08-02-2013, 01:07 PM   #9
At least rent a laddervator.
http://www.ebay.com/sch/i.html?_nkw=laddervator
Installing the shingles is easy, getting them up on the roof is the hard part.
Home Depot and most rental company's have them for rent.
Old 08-02-2013, 03:07 PM   #10
Gymschu's Avatar
Rewards Points: 652
Having done my own roof (I am a painter by the way) was a backbreaking task by myself. Of course I did a lot of it during the winter (slow months) which didn't help. Definitely get the shingles up on the roof. You don't want to haul a dozen or so at a time up the ladder like I did. I started with a hammer and ended up buying a coil nailer. It does speed things up, but not as much as you may think if you are by yourself. It helps to have a buddy feeding you shingles as you go. In the end, I did not save any money. I could have had a real roofer do it for about the same cost that I did it. Once you add in the removal of old shingles, the time spent on the roof, the tools you need to buy, the discount the roofer gets, etc. well, you just don't save too much.
Old 08-02-2013, 07:35 PM   #11
PoleCat's Avatar
New flashing is already on the mast. It is held up about three feet from deck with tape.
Need Opinions ASAP - Roofer causes expensive problem with furnace MB1 Roofing/Siding 9 06-20-2012 09:04 PM
Leaking Ceiling, Do I Need a Roofer? Phreek Roofing/Siding 31 04-09-2011 03:24 AM
Roofer refuses to use 30# felt Dodah Roofing/Siding 12 06-23-2009 11:17 AM
Would this be a good deal for a roofer or is it a dumb thought Doug Crf Roofing/Siding 5 05-09-2006 10:44 PM
