Not Having Downpipe Across Roof Bad For Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-08-2010, 10:05 AM   #1
Rewards Points: 101
Not having downpipe across roof bad for roof?
Like several houses in the neighbourhood ours has gutters from the dormers running backwards and then a downpipe just to the roof so as to let the water drain down and across the roof to the gutters at the lower edge.
The home inspector said a downpipe should be added to run down across this span so that the water runs through it and not over the shingles.
Right now the problem seems to be a discolouration extra fungus-type buildup on the water track.
Can this perpetural stream across the duroid-type shingles be damaging or shorten their life, or is it just more unsightly? I've heard it is just an aesthetic issue.
House is on the wet west coast.
Hossenfeffer is offline   Reply With Quote
Old 09-08-2010, 10:44 AM   #2
Those areas will fail prematurely.Seen it many times.
johnk is offline   Reply With Quote
Old 09-08-2010, 07:20 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
i never just drop onto another roof,i will offset the leader down the side wall if i have too,or i will run a leader directly into the lower gutter
Tom Struble is offline   Reply With Quote
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
