Is It Normal For The Soffit To Get Wet Like This? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-11-2013, 09:04 AM   #1
Is it normal for the soffit to get wet like this?
I just noticed this today. There was a puddle on the ground and no rain last night, not sure where the water is dripping from, but I'm assuming its condensation for now. The home is 3.5 months old. No rain gutters in the front of the house (where pic was taken), only on sides. I haven't checked the rest of the house yet.
cnguyen is offline   Reply With Quote
Old 09-11-2013, 09:10 AM   #2
Rewards Points: 13,458
For one thing they left the shingles sitting to far back. They should have hung over the edge at least 1/2.
Posting your location in your profile would be a big help.
Reason being I know in my area it's code to install Storm and Ice shield to the lower edge of the sheathing before the paper and shingle go on to help prevent things like this from happening.
I'd be up on a ladder checking to see if there's even a starter strip, the seams do not line up in the starter strip and the shingles, the tar paper over laps the drip cap.
Old 09-11-2013, 09:11 AM   #3
We live in FL.
Old 09-11-2013, 09:18 AM   #4
So I'm assuming something is wrong here. We live in Tampa, FL.
Old 09-11-2013, 09:22 AM   #5
PoleCat's Avatar
Rewards Points: 1,646
Is your AC in the attic? Could be condensate from that. You say no rain fell and a heavy dew sounds unlikely in Florida. Only other thing I can think of is big fat oppossum urine or a kid with a hose.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-11-2013, 12:55 PM   #6
Rewards Points: 1,002
I wouldn't be surprised if one of today's high speed cost cutting builders ended a bath vent there.
Old 09-11-2013, 02:42 PM   #7
AC is not in the attic. I had a builder rep come out and check it and he said it was normal. But it seems like he was shrugging everything off like saying "it's the exterior of the home, it'll get wet. That's what it's there for, so the inside wont get wet. It's prob just dew." About the shingles, he said they're done correctly and they try to cut it very close to the drip line or edge or something or another.
Old 09-11-2013, 03:53 PM   #8
I suggest you get plenty of pictures and documentation including the name and date of the builder rep visit and what he said as close as you can recall. I can guarantee you'll be talking with these folks again at some point, possibly in court.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
woodworkbykirk (09-11-2013)
Old 09-11-2013, 05:36 PM   #9
kwikfishron's Avatar
Rewards Points: 416
When was the last time it did rain and how much?
I can see water as high up as the edge of the shingles. I've seen roof leaks that took a day or so to finally find there way out and be visible.
Any access to that area of the attic?
kwikfishron is online now   Reply With Quote
Old 09-11-2013, 05:44 PM   #10
His reply was total BS!!!!!!!!!!!!!!!
It's also his job to save the company money to keep his job.
No way should a soffit be dripping water unless someone just pressure washed or there was a hurricane!
Look on any shingle company's web site and read the install directions.
Not ones going to say it's ok to install shingles with no or that little an over hang.
Old 09-11-2013, 07:43 PM   #11
I think it rained about a 3-4 days ago. The home is two story and that part is over the garage. I'm not sure if we can access it. I'm trying to get someone else from the builder to come out and take a look, but that seems very difficult at this point.
Old 09-11-2013, 07:49 PM   #12
I agree. I looked at the neighbors home and their soffit does not have drip stains or is dripping. I even asked him if the shingles should come out a little more and he says "no, the roofers try and cut it as close to the drip as possible. No over hang." He refused to get a pro out to take a look. This is a new rep that was just transferred into the subdivision, and he's pretty rude. Kept on saying he's been doing this for 15 years.
Old 09-11-2013, 08:06 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
ive seen this type of leak once. and that was caused by having no step flashing.. water was getting in under the shingles up along the sidewall and the water was getting under the shingles running down the roof then under the drip edge and down into the fascia cladding then coming out of the soffit..
something tells me that roof might be getting stripped a lot earlier than the 25 years which is what their warrenty'd for
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Windows on Wash (09-16-2013)
Old 09-11-2013, 08:48 PM   #14
Rewards Points: 416
I've seen it many times......looking at the picture, condensation is way down on my list of what might be going on.
Old 09-11-2013, 09:48 PM   #15
Maybe I can try to find another Rep to come out and take a look. The one that came out today was pretty sure he knew what he was talking about and will not get a roofer to come and check it out. I guess if that don't work I'll have to get a home inspection done since the home is still under 1 year warranty. Btw, we close on May 31st, 2013 and there has been so many problems already. I'm not surprise if someone halfassed this job.
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 09:12 AM
bathroom soffit..is this normal? twenty2 HVAC 13 02-03-2012 04:18 PM
Soffit Vents Atskodinski Building & Construction 6 03-05-2011 12:19 PM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 06:36 AM
Dropped soffit over shower? StevePax Remodeling 2 12-24-2009 11:24 AM
