Normal For Fascia To Look Wavy? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-09-2010, 05:32 PM   #16
kwikfishron's Avatar
Rewards Points: 370
Originally Posted by tomstruble View Post
i do a bit of cedar too,just finished up a handsplit tyin job,sorry about the pics camera was set wrong
back to the op thats kinda my point Ron once the gutter goes on there won't be an issue
West Coast Cedar to boot.
Love the ladder table, looks like most of my setups. Them Orshore boys donít think much of it though.
Not trying to derail the thread but I have to know. How much a sq. for the reds in NJ?
kwikfishron is online now   Reply With Quote
Old 10-09-2010, 05:39 PM   #17
Tom Struble's Avatar
Rewards Points: 2,002
idk they were supplied by the contractor on this one.ill find out and let ya know
Tom Struble is offline   Reply With Quote
Old 10-09-2010, 06:36 PM   #18
Rewards Points: 192
thanks
Wow, thank you all for the responses! I didn't expect to get this many in return.
Thanks for all the valuable information. Yes, I agree with some of the other posts. I believe that it's a thin gauge of aluminum that was used, and that doesn't give it the ridgidity. I also believe that once the gutters are up, it will look better. Not great, but a lot better.
The areas where there won't be any gutters look a little better; i only took pictures of what i thought were the worse. I checked other houses in the subdivision and theirs are like that as well. I suppose the bottom line is just making sure that there is a good seal so that it doesn't leak water. Yeah, it should probably be a thicker aluminum, but I suppose they have to draw the line of where the price point is.
Somebody said something that made it sound like there may be a larger problem, but the original poster (me) didn't ask about it....what was it?
The vents that are in the soffit are for the bathrooms.
Thanks again for all the responses!
wiz561 is offline   Reply With Quote
Old 10-09-2010, 06:38 PM   #19
its probably .019 which nowadays is the ''industry standard'' unfortunately
Old 10-09-2010, 06:41 PM   #20
Rewards Points: 192
btw, how much would it be to replace it in the future? The house is about 60' long and 55' wide....
Old 10-09-2010, 06:49 PM   #21
like how long in the future? i really can't say sorry
Old 12-30-2010, 03:06 PM   #22
Looks like vinyl soffit and vinyl fascia. Whether vinyl or aluminum it should not look that way. Fastening a gutter over wavey/warped facia will probably compound the problem rather than alleviate it. Also, several of the siding seams look suspect and I don't think the siding was snap-locked into finish trim under the windows causing the siding to "wave" as well.
I'd get the installer out to correct the problems right away.
larryb is offline   Reply With Quote
Old 01-04-2011, 10:40 AM   #23
Rewards Points: 150
The main thing imo is do the waves in it cause it to roll out from under the drip edge, if so water can get in behind the metal and rot the wood. They can put a hem on the aluminum to make it more rigid and not wave as much. The main thing is it needs to be under the drip edge good.
guest is offline   Reply With Quote
coolant indicater staying cooler than normal raptor99 Automotive Repairs 5 02-16-2010 03:19 AM
laminate floating floor squeeky, is it normal? gagaliya Flooring 1 10-02-2009 05:27 AM
Controversy or normal? fogelbise Flooring 1 06-18-2009 08:45 AM
backup sump pump does not clear the pit when triggered, normal? abefroman Plumbing 3 02-20-2009 04:14 PM
damage to prefinished floors normal during a remodel? zzman Remodeling 15 12-04-2008 05:25 PM
