Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-11-2005, 02:48 PM   #1
No starter strips
:confused:
Hello
We are almost ready to roof our shed, but noticed that we don't have any starter strips. We called the store and they suggested two options:
1. Turn a full shingle upside down and use it for a starter strip.
2. Do the same thing as above, but cut the tabs off.
I don't know if either one is correct or not at all! Without alot of experience, I don't know how to nail it down if you cut the tabs off???
Thank you for your help.
Mike
fishwi is offline   Reply With Quote
Old 10-11-2005, 08:32 PM   #2
aka:awesomedell
Send a message via MSN to housedocs
No starter strips
Either suggestion is acceptable, personally I cut the tabs off. HTH
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 10-11-2005, 11:36 PM   #3
renovations
No starter strips
Starter strip is nice but not necessary. Turn the three tabs upside down and nail them around the level of the tar-line. It's a good idea to start with just two of the three tabs (ie cut it), this way you can start your roof proper with a full shingle without the joints happening on top of each other.
Bonus is offline   Reply With Quote
Old 10-12-2005, 07:30 AM   #4
Commercial Roofing
AaronB's Avatar
No starter strips
Cut off a half a tab if you do it this way. Otherwise youre still left with the butt joints over the slots with very little coverage.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 10-12-2005, 10:32 AM   #5
No starter strips
Thank you so much for all the help.
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 02:34 PM
replacing starter boards Bob C Roofing 6 07-17-2007 01:04 PM
Recommended way to attach firring strips to Drylock wall? jbwaechter Building & Construction 1 04-29-2007 05:08 PM
CertainTeed starter shingle ? MACCC Roofing 2 04-20-2007 03:26 PM
Best furring strips? J187 Building & Construction 5 06-03-2006 10:41 AM
