Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-26-2012, 09:33 AM   #1
No spacers/clips on my OSB roof
My house is a little more than 5 years old. Noticed there are no spacers/clips between the OSB sheets on the roof. I haven't noticed anything bad happening, just curious since my detached garage does have the clips...
MisterSteve is offline   Reply With Quote
Old 02-26-2012, 09:35 AM   #2
KemoSabe
loneframer's Avatar
What is the spacing on the rafters? What is the thickness of the sheathing? Is it T&G?
All these things will have a bearing on the need for clips.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
mae-ling (02-26-2012)
Old 02-26-2012, 09:53 AM   #3
Rafters are on 16's, Thickness is 7/16". The panels say to "space 1/8" on ends for proper performance". Some seem spaced more accurately than others. No indication of whether or not it is T&G on the panels. They don't appear to be T&G.
Old 02-26-2012, 10:04 AM   #4
Should be fine, look for a grade stamp on the panels, it will look like this.
http://www.apawood.org/perf_panels/A...ts-Oct2011.pdf
It would have been better to have had H clips for less chance of a sag between the rafters and give you the needed spacing but not required on 16" spacing.
Old 02-26-2012, 10:15 AM   #5
Is that the main purpose of the clips? To prevent sagging? I was thinking they are for expansion in the heat. Makes sense though, my garage has them between the 24" spaced rafters.
I am not in any construction field, but stuff like that would bother me if I knew I could spend another $20-$30 on something that can only help the roof last longer and look better....Those clips are probably 5-10 cents or something?
Old 02-26-2012, 08:02 PM   #6
KemoSabe
loneframer's Avatar
You should be fine on 16"s, provided the panels don't expand and bind, causing buckling. In which case, the clips would keep the panels from buckling in opposite directions, not prevent it entirely.
Old 02-26-2012, 08:28 PM   #7
Framing Contractor
While H clips are not required on 16 inch centers, we almost always put them in. Helps to keep the spacing consistent.
sixeightten is offline   Reply With Quote
Old 02-26-2012, 08:33 PM   #8
"I was thinking they are for expansion in the heat."
so did I, I just learned something.
Hardway is offline   Reply With Quote
Old 02-26-2012, 09:47 PM   #9
RFN-4A-LVN
Roofmaster417's Avatar
I have seen guys set 8b or 16b to give proper spacing.,but depending on the centers and thickness of the decking the sag issue might not be a factor.
Roofmaster417 is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing 22 09-14-2012 01:19 AM
Tell me about roof coatings for an older roof Leica Roofing 3 09-19-2010 02:55 PM
Flat roof and insulation quandry paredown Roofing 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing 15 11-07-2009 06:48 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
