Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-18-2012, 08:51 AM   #1
Question
No Gable Roof Access
Hello,
My question is, the main roof is a gable version running parallel to the street. Attached to this is another small gable section pointing toward the street with a gable vent attached to it's face. There is no access from the attic into this smaller area with the vent. Can I cut an opening through the main roof to this area between the rafters? I need to repair the gable vent, which is about 30 feet up, and I would prefer to do it from attic access. I would like to remove the vent via the attic, repair and paint on the ground and replace it via the attic. Leaving only the caulking to be done 30 ft in the air. Yea, I don't like landing from that height.
Any thoughts?
1Logan is offline   Reply With Quote
Old 03-18-2012, 10:15 AM   #2
STAFF
BigJim's Avatar
You can cut the decking from below to access the dormer but not a rafter without installing a header. Chances are the vent will have flanges nailed from outside, unless it is a wooden one. If it is a wooden vent is the trim nailed to the vent from outside? Chances are it is.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
Old 03-18-2012, 03:05 PM   #3
About a 0 % chance of being able to do this from the attic. The flange and trim are all on the outside.
Old 03-19-2012, 12:18 AM   #4
Thanks for the reply's, guys. Guess I'm looking for a sub-contractor!
All the best,
T
add shed roof to gable roof lucy1 Roofing 0 10-30-2011 09:31 PM
Condensing furnac vent: 4' through roof or 20' through gable? mysterylectric HVAC 3 01-19-2011 03:33 PM
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Gable Roof Span Gandalf Building & Construction 2 04-29-2010 10:45 PM
Insulation in roof rafters at the gable end nofx1981 Roofing 5 03-09-2010 04:21 PM
