Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-16-2010, 11:10 AM   #1
No drip edge
My house is sided with Hardie cement siding, including the fascia. I had a new roof put on with plywood and all. The roofer didn't use drip edge. He said it wasn't needed. He used ice/water shield on the eaves and rakes, starter strips, etc, and let the shingles overhang a good inch or so right into the gutters. Is this acceptable? For what it's worth, he used 30 yr gaf timberline shingles. I live in Southeastern Pa.
rakuz66 is offline   Reply With Quote
Old 12-16-2010, 12:21 PM   #2
Chicago, IL
Michael Thomas's Avatar
No drip edge
In my area, anyway, lack of eave flashings is a invitation to water backup under the shingles from ice at the gutters and eaves.
Drip edge is "recommended" (not "required") by most shingle manufacturer's, but is not required by the IRC.
In your case the manufacturer's installation instructions say:
"NON-CORRODING METAL DRIP EDGES: Recommended along rake and eave edges on all decks, especially plywood decks."
and the installation instructions illustrate dip edges for both standard and low-slope applications.
So the roofer is technically correct when he says the drip edge is not "required", but it's also the case that the roof is not installed in accordance with the manufacturer's written recommendations - which IMO is a pretty low standard to shoot for.
BTW, are gutter end separations from adjacent walls:
hold-backs from roofs:
and kick out flashings:
present as/where required by the James Hardi installation instructions?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 01-10-2011, 08:29 PM   #3
No drip edge
Drip edge is not used on shingles in different areas of the country,as long as he left you overhang it will be fine.Ive seen with or without work fine over the years.
Robert F is offline   Reply With Quote
Old 01-10-2011, 10:28 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
No drip edge
Before I started on my own I sub contracted from one of the largest roofing companies in STL, In St.Louis it is an option only accessory., unless it was a storm damaged claim and then you install the roof according to the insurers authorized materials.Then I moved to Springfield and started on my own.Here everyone has drip edge . The DE is figured in.The company that I subbed from required 1" on the rakeline, and 1-1/2" in the gutters.And it was required (overhangs) even with the drip edge , In my opinion if the gutters and all accessories, Gutters themselves,,downspouts, elbows are in great condition and are free of debris.,and the water from the downspout are is properly channeled away from the house then I don't feel that Drip edge would be an issue.
Roofmaster417 is offline   Reply With Quote
Ice and Water Shield under drip edge? sutterml Roofing 10 07-11-2011 06:04 AM
roof drip edge billygale Roofing 9 10-24-2010 03:19 PM
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing 4 10-24-2010 02:18 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing 4 10-07-2009 11:49 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing 32 02-15-2008 03:10 PM
