Newly Installed Asphalt Looks Horrible (See Pics) - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-02-2012, 10:04 PM   #16
Originally Posted by joecaption View Post
That's a mess.
Also the top of the valley is wrong, the rake board and shingle mould was installed wrong.
It may be just the picture but in the last one it almost looks like one of the cources is
Thanks for your critique. I will run your comments by my general contractor.
pmay is offline   Reply With Quote
Old 11-02-2012, 10:10 PM   #17
Originally Posted by CIT View Post
That looks terrible!!!! I'd be sick!!
believe me it did make me sick - that's why i posted and asked for opinions. Day 2 they completed job....hoping some sunshine will make a difference.
Old 11-03-2012, 07:45 AM   #18
Rewards Points: 13,732
Are they planing on wrapping the shingle moulding and the fashia with coil stock?
Reason I ask is to help keep it from cupping and rotting it should have been primed and painted before installing, that bottom, short piece was installed wrong so now there's exposed end grain showing, right were it's most likly to have water dripping off of it.
The rake moulding was cut to short, it should have been run all the way to the end of the fashia.
Old 11-04-2012, 08:05 AM   #19
Roofing Contractor
This time of the year we tell all customers before we start that some shingles may looked bubbled. They are reminded with warm temps and sun the shingles will lay down just fine. If this is a big deal they schedule in the Spring.
dougger222 is offline   Reply With Quote
Old 11-04-2012, 08:06 AM   #20
Roofing Contractor
BTW,
Looks like most of the slope on the right pic was racked instead of stair stepped. You may want to check with the manfuacturer of the shingles to ensure this an approved method of application.
Old 11-04-2012, 09:17 AM   #21
RFN-4A-LVN
Roofmaster417's Avatar
[QUOTE dougger222) You may want to check with the manfuacturer of the shingles to ensure this an approved method of application.[/QUOTE]
I noticed a lot of racking Archs in my area.So my guys made mention of trying it.I said I don't think so.
I called Certainteed,Tamko and O.C and all 3 said the same.Its not a recommended or approved application technique.
Roofmaster417 is offline   Reply With Quote
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 07:39 PM
Stucco over my cedar wood paneling vs stucco over newly installed plywood beesan Building & Construction 5 12-21-2009 12:24 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Sealing newly installed pre-finished bamboo flooring brandon272 Flooring 2 06-10-2009 10:25 PM
Newly installed Thermostat doesn't power on falcon753 HVAC 17 10-28-2008 08:53 AM
