Newbie W/ Fascia Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-18-2009, 10:07 PM   #16
If the sticker shock to have someone else do it is too much, I may consider it. Thanks.
Originally Posted by framer53 View Post
One thing my friend, with a little playing you can brake aluminum and you will find that brakes can be rented!
NWallen is offline   Reply With Quote
Old 07-19-2009, 01:00 PM   #17
Rewards Points: 258
Should you decide to install aluminum facia covering, it can be bent at both the top and bottom to look like this "[" with the upper edge under the shingles (but above the felt) and the lower edge covering the bottom of the facia board for a nice clean look. I'd probably make the under- the- shingle portion about 2 inches wide. Then I would dispense with the drip edge. Some purists will say that you will still need a drip edge but then the appearance would be somewhat compromised and in my opinion it is not necessary. If you dispense with the top bend for some reason, I would definitely install a drip edge which would overlap the aluminum facia covering. Be sure to get the right style drip edge for this application. You'll find an extra set of hands and a second ladder very helpful if you decide to do the job yourself. It is certainly doable as a diy project if you can rent a brake. You will want to purchase some aluminum nails for this project. You can get them with white enameled heads to match the aluminum.
retired guy 60 is offline   Reply With Quote
More painting questions from a newbie. Tab1975 Painting 5 04-24-2009 11:13 PM
Track Lighting newbie questions GFW Electrical 1 04-18-2008 10:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Newbie here and need help with questions sil General DIY Discussions 3 09-28-2007 06:23 PM
