Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-29-2010, 09:16 AM   #1
Newbie roofing a shed with a gambrel roof
I've browsed the board and read what I can find about shingling a gambrel roof but I still have some questions, please.
I've built one of those DIY storage buildings for my wife's gardening equipment and stuff. Nothing fancy. I'm ready to put shingles on it, but I'm not sure what else I should do. Especially when I get to the line on both sides where the two different slopes meet. I know how to make ridge shingles (is that the right term?) for the top but I'm not sure what to do at the other two lines.
1. I've got drip edge for the front and back edges of the roof, but not for the edges along the two side walls. Should I use drip edge all around? Either way, do I use regular roofing nails on the drip edge too?
2. The instructions for the building don't mention any sort of underlayment at all. No felt, nothing. I live in upstate SC, so I don't plan on using any sort of ice/water shield. But should I still put down a layer of felt beneath the shingles? Do I use regular roofing nails here?
3. If I do use felt, does it go down first and then I put the drip edge over the felt, or the other way around?
4. Finally, the $64,000 question [how many others of you also remember where THAT comes from?!] From the messages I've read, it appears I need to use flashing at the lines where the slopes change. I put that over the shingles on the lower, steeper part and beneath the first course of shingles on the upper, flatter part. Right? How do I fasten it to the roof? Do I nail through the upper part but not the lower part? If yes, how do I bend it so both parts lay flat?
Assuming that's right, that seems to say I need to cut off the top course of shingles on the lower part, right at the line where the slopes change, NOT just bend them over onto the upper part. Right?
And still assuming I'm on track here, I assume I start the first upper course with its lower edge right about where the line is between the two parts of the roof, so that it doesn't bend over either. Right?
Sorry for lots of questions, but I want to get it right. It's a sorta present for my wife, and if I mess it up, well, you know....
Thx.
tomseeley is offline   Reply With Quote
Old 06-29-2010, 10:59 AM   #2
Shut in w/o Home
seeyou's Avatar
I'd use drip edge all the way around. Yes on the roofing nails.
Yes on the felt and the nails.
Drip edge over the felt on the sides, under on the bottom.
4.it appears I need to use flashing at the lines where the slopes change. I put that over the shingles on the lower, steeper part and beneath the first course of shingles on the upper, flatter part. Right?
Right
yes
you need to purchase it bent or have someone with a metal brake bend it for you.
right
Right
seeyou is offline   Reply With Quote
Old 09-08-2010, 01:11 PM   #3
Read more: How to Install Asphalt Shingles on a Gambrel | eHow.com
http://www.ehow.com/how_5977480_inst...#ixzz0yxRPXERE
I came across your problem and am sorry I was not a member at the time.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Roofing a shed - Need some opinions TANC Roofing 12 01-29-2010 09:14 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing 3 11-06-2009 10:07 AM
Shed Porch roof tying in... my5sons Roofing 7 10-27-2009 09:19 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Rudimentary Shed Roofing Question CGofMP Roofing 11 03-31-2006 10:24 AM
