New Tar Paper With To Tie In With Existing Roof Tar Paper. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 03:37 AM   #1
Rewards Points: 12
new tar paper with to tie in with existing roof tar paper.
Hi, I have an existing roof that is less than 10 years old and I have just added an addition. Part of the shingles needed to be removed but the original tar paper has be left on.
What is the best proper way to tie in the new tar paper with the existing one? Lay it over the existing one? Slip it under?
I attached a picture.
thanks
new tar paper with to tie in with existing roof tar paper.-img00328-20110620-1841.jpg
accordfreak is offline   Reply With Quote
Old 06-24-2011, 07:58 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Use Ice and water shield in the valley. It can stick to the existing felt, although it would be preferable to cut the existing and slip the I&WS under it. Then install the new felt over the other side of the I&WS.
If you elect to use only felt in the valley, cut a separate piece to lay down the valley and install it under the existing and the new. And then make sure you don't tear it stepping on it.
seeyou is offline   Reply With Quote
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Tied in Porch Roof to Existing Roof - Leaking bharling Roofing/Siding 29 03-08-2011 05:06 AM
Need a good reference for tying in a Porch roof (gable) onto existing Hip roof bamawoody Building & Construction 5 04-17-2010 04:19 PM
deck roof addition to the existing roof maggiedulzaides Building & Construction 1 10-21-2009 01:07 PM
Installing over Existing Shingled Roof meth Roofing/Siding 11 11-15-2008 06:18 PM
