Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-01-2012, 08:04 PM   #1
new rubber roof over old
I have a flat rubber roof (slightly pitched 14 degrees) I would like to know If I can place new rubber directly over the old one or do I have to strip it first?old roof is in pretty good shape approx 18 years old,no leaks . just want to replace as part of preventive maintenance. can I glue directly over old using either black or white rubber? no soft or spongey spots on existing roof.
DENIS RONAN
DENIS RONAN is offline   Reply With Quote
Old 08-02-2012, 12:44 AM   #2
(I am making some assumptions here as I don't know the details of your whole system) - You won't be able to glue new EPDM to the old. The roof will be too dirty.
It would be much better to strip the old, then add a 1/2" fiberboard, then adhere the new EPDM. Black EPDM will last more than twice as long as white.
roofnron is offline   Reply With Quote
The Following User Says Thank You to roofnron For This Useful Post:
DENIS RONAN (08-02-2012)
Old 08-02-2012, 06:47 AM   #3
Exterior Construction
Windows on Wash's Avatar
+1 to Ron's advice.
Going overtop, even with shingles, is rarely advisable.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 08-02-2012, 12:50 PM   #4
Doing This Way Too Long
You cannot put any single-ply over a single-ply. Good news though, it's really easy to remove the old.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Proper transition between shed roof and shingled roof? aribert Roofing 9 04-12-2012 04:17 PM
rubber roof Fanatic Roofing 2 11-10-2011 04:16 PM
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
