Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-07-2005, 09:24 AM   #1
New roof on top of new roof?
I have a new Elk Prestique I High Definition roof. All old roofing were tear-off. The roof supplier delivered the wrong color roof and the contractor put it on anyway. Now they offer to put the right color roof on top of the existing new roof.
Should i ask for a tear-off? Would there be a problem of moisture trapped between the 2 layers? Would the roof look better starting with a flat surface? Would ventilation be better with only 1 layer of new roof?
Thank you very much.
araws is offline   Reply With Quote
Old 12-07-2005, 10:06 AM   #2
I believe I'd insist on the tear off for a number of reasons but the roofers should be along here shortly to give you the straight scoop. HS.
K2eoj is offline   Reply With Quote
Old 12-07-2005, 11:51 AM   #3
Mod / ArchiBuilder
Cole's Avatar
As I recall, you are not allowed to install new shingles on an old layer.
I would demand a tear off at there cost.
Keyword = DEMAND
Cole is offline   Reply With Quote
Old 12-07-2005, 12:02 PM   #4
I think we're still allowed 3 roofs but it is very rearly done. Those fellows can tear off a roof faster than i can drive to home depot. HS.
Old 12-07-2005, 07:49 PM   #5
Commercial Roofing
AaronB's Avatar
It is the contractor's responsibility to install the correct roofing system for you.
You have the right to receive the job you paid for. Ultimately, no matter what color was delivered, it is the contractor's responsibility to make sure it is the right color, brand, lifespan, etc.
If you go over a heavy architectural, it will look terrible and fail prematurely.
I would have to say you need to insist on the job you paid for, and no band-aid cures.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
leaking tar and gravel roof meleis Roofing 9 01-05-2008 11:27 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
