New Roof Smell Getting Through Skylights - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-20-2012, 05:46 PM   #1
New roof smell getting through skylights
I just has a new roof installed and the smell from the new roof gets into the house through the skylights when it is hot outside...sunny and over 70 degrees.
I have 7 skylights throughout the home and they all leak the roofing smell.
The roofer came back an even placed foam weather stripping between the wood and the skylight to seal it even better.
The smell is the same and it makes it hard to breath or to use the air conditioning since then the smell gets thrown throughout the home.
Any suggestions to fix this problem would be very helpful?
jettipio is offline   Reply With Quote
Old 04-20-2012, 07:01 PM   #2
Rewards Points: 14,306
Might help if you mentioned what type roofing it is.
Old 04-20-2012, 07:04 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
Do you have a hot tar roof/rubber etc ?.,
Without trying to sound smart I have not been able to tell a new roof smell from an old roof.,minus the mold of course.
What does it smell like ?
Did you have 3 tabs before and now maybe an architectural roof ?
Roofmaster417 is offline   Reply With Quote
Old 04-20-2012, 08:28 PM   #4
I have a standerd 30 year shingle roof and smells the the back side of the shingles.
Old 04-20-2012, 08:43 PM   #5
Doing This Way Too Long
Rewards Points: 532
never heard of such a thing. Shingles don't "smell"
OldNBroken is offline   Reply With Quote
The Following 2 Users Say Thank You to OldNBroken For This Useful Post:
kwikfishron (04-20-2012), Roofmaster417 (04-20-2012)
Old 04-20-2012, 10:17 PM   #6
RFN-4A-LVN
Did you have 3 tabs before ? hahahahaha.,Just kidding.,Maybe what your smelling is the over use of an adhesive or sealant in hopes that the skylights never leak.
I knew a guy who used 12 tubes on a single reroof with 4 skylights.,crazy,,,,I bet that is what you are smelling.
Old 04-20-2012, 10:26 PM   #7
kwikfishron's Avatar
Rewards Points: 998
New Cedar ones do.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
OldNBroken (04-21-2012)
Old 04-20-2012, 10:27 PM   #8
That's what I was starting to think. Does it smell like acitone?
I'm thinking silicone.
Old 04-20-2012, 10:51 PM   #9
RFN-4A-LVN
Did your contractor build the curbs on the skylight ?.,You might be smelling the type of wood he used maybe for some reason it was treated.?
Old 04-21-2012, 12:26 AM   #10
If you smell the backside of shingles especially when they are in the sun for a while they smell like tar. Tar is the smell infiltrating in where the skylights are.
It is especially strong in the upstairs bedroom area where I can stand and touch the skylights.
No adhesive has been used to seal the skylights.
The smell is a tar smell.
Old 04-21-2012, 09:29 AM   #11
The new shingles were placed on top of the old shingles. The skylights and wood were not changed
Old 04-21-2012, 10:08 AM   #12
Rewards Points: 790
Were the shingles wet when placed on the roof? Wet shingles tend to have a foul smell. It will go away eventually. You might just be getting used to the new smell of asphalt. It'll go away,
cibula11 is offline   Reply With Quote
Old 04-21-2012, 05:20 PM   #13
It occurred all last summer and is starting again this summer. Very powerful when it gets warm.
Old 04-21-2012, 05:32 PM   #14
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Never heard, or had a complaint like that.
Are you overly sensetive to odors (serious question)?
Possibly there was some other material, urethane, or petroleum based product used around the skylight that can be emitting an odor???
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
Roofmaster417 (04-21-2012)
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Are roof skylights leaking? Halron Roofing/Siding 3 04-15-2007 02:06 PM
