New Roof Quote, Help Needed - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-31-2011, 08:03 PM   #1
New Roof quote, help needed
We are in the process of obtaining quotes to replace our 25 year old shingled roof. Please advise if the quote, which is found below is sound in regards to quality roofing products. Thank you in advance for your response.
Mike
Remove Existing Shingle Down to Roof Decking
Replace any Damaged Plywood at $40.00 per 4 x 8 Fir Sheet -
Install GAF/ELK Weather Watch Along Gutter Line, Valleys and Chimney
Install 15lb. felt in all other areas
Replace Damaged Base, Step and Counter Flashing
Install C31/2 Metal Drip Edge Around Perimeter
Install Pipe Flanges
Install GAF/ELK Pro-Start Eave/Rake Starter Strip -
Install 30' GAF/ELK Cobra Vent or GAF/ELK Pro 2 Master Flow Power Vent -
Install GAF/ELK Timbertex Premium Ridge Cap Shingles-200' -
Install GAF/ELK Timberline High Definition Shingle Prestique 30 Year-35sq
Clean Gutters at Completion of Job -Waste Removal, 20 Yard Container and Permit Supplied by Contractor
10 Year Workmanship Warranty and GAF/ELK Systems Plus Warranty Included
NOTE: DETACHED STRUCTURE INCLUDED IN ESTIMATE-NO -
NOTE: NOT RESPONSIBLE FOR DEBRIS IN ATTIC OR CONTENTS IN OR AROUND THE PREMISES
NOTE: NOT RESPONSIBLE FOR SATELLITE DISHES AND/OR RECEPTION
NOTE: ADDITIONAL ROOF LAYERS NOT RECOMMENDED
NOTE: INSTALL VELUX FS C12 WITH FLASHING KIT AND LAMINATED GLASS $665.00 PER, NOT -CLUDED IN ESTIMATE -
NOTE: INSTALL VELUX FS D26 WITH FLASHING KIT AND LAMINATED GLASS $350.00 NOT INCLUDED IN ESTIMATE -
Owner Will Pay Contractor for Performance of the Work Described Herein $9,925.00 Payable as Follows: -$4,000.00 Deposit Upon the Execution of this Contract.Balance Due Upon Completion -
VISA, MASTERCARD, DISCOVER AND AMERICAN EXPRESS ARE WELCOME! -
The work shall commence no later than ,20 ,and shall be completed within calendar days of that -
date. Contractor shall not be liable for any delay or nonperformance caused by an act of God, strikes,
unavailability of materials, or any other contingency beyond it's control. -
kiropod is offline   Reply With Quote
Old 03-31-2011, 08:47 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
"Install GAF/ELK Weather Watch Along Gutter Line, Valleys and Chimney"
Depends on the eave. A 2' overhang, straight out, is nearly 3' of roof on a 4/12 pitch. It wouldn't serve any purpose in that case. The weather watch must cover an area that represents a minimum of 2' inside the living area. You'll have to do a bit of math there to see if you are being served correctly. Most homes need two courses, 6', to be effective.
tinner666 is offline   Reply With Quote
Old 03-31-2011, 09:24 PM   #3
Roofing quotation
Is the GAF/ELK Timberline High Definition Shingle Prestique 30 Year shingles a quality product?
Old 03-31-2011, 10:11 PM   #4
That shingle doesn't exist anymore. That guy needs to update his information.
BamBamm5144 is offline   Reply With Quote
Old 04-01-2011, 02:07 AM   #5
Doing This Way Too Long
Rewards Points: 532
Sounds like a very thorough proposal. Other than, yes, they are GAF timberlines now.
OldNBroken is offline   Reply With Quote
Old 04-01-2011, 07:35 AM   #6
Roofing quotation
Thanks for your help!
Old 04-01-2011, 09:25 AM   #7
MJW
The quality of the shingles depends quite a bit on your location. Timberlines are borderline, ummm, junk up here.
I'd be a little more concerned with specifically WHO will be physically working on your house. Just as important if not more so than the products used.
MJW is offline   Reply With Quote
Old 04-01-2011, 01:04 PM   #8
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
If I understand correctly, the shingle still exists, but the name/warranty has changed. All this updating. I'm still getting things changed over from the 25 yr to 30 yr warranty change.
seeyou is offline   Reply With Quote
Old 04-01-2011, 01:07 PM   #9
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
They're borderline here, as well. But south of the border.
The factory they originate from seems to be more important than the brand, quality wise.
The Following User Says Thank You to seeyou For This Useful Post:
MJW (04-01-2011)
Old 04-01-2011, 06:48 PM   #10
New Roof
We are using a very reputable roofer, who is a patient of mine. From what I've learned on the web, this product seems to have a good reputation. For Southern NJ, what would you recommend?
Mike
Old 04-01-2011, 07:05 PM   #11
MJW
Mike
How about this.....If he is a reputable roofer, why not trust him? His opinion should mean more to you than random people on a DIY forum.
I'm not from the area, so I cannot say how good each brand is.
Like I said, how is he reputable? Does he put the shingles on? Does he have a good crew? Does he use sub-contractors? Does everyone have proper license and insurance, including any subs? Is there a building permit and inspection.
Many things are just as important as the materials used.
Hope it works out for you.
Old 04-01-2011, 07:07 PM   #12
MJW
I would question the skylights. Vellux doesn't make a skylight with a flashing kit anymore. They may want to double check that for pricing.
Old 04-01-2011, 07:28 PM   #13
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Sure they do:
http://skylights.veluxusa.com/consum...ghts/flashings
They do make a line of curb mounted units now, but they still make the integral curb units they always have. They changed the mounting system - for the better.
MJW (04-01-2011)
Old 04-01-2011, 07:34 PM   #14
RFN-4A-LVN
Roofmaster417's Avatar
OP,the proposal seems thorough IMO.On my contracts I have an area that says,
Upon project completion prior to final payment Roofmasters 417 will supply a lien waiver from our suppliers to show materials being payed.It also states that the customer will receive in writing the workmanship warranty and details therein.It also states that shingle warranties will also be given.
The lien waiver is very important.If materials are not paid and a lien release is not submitted then you could have a lien put on your property from the shingle distributer until the materials are paid in full.That means you will have paid for them twice.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
oh'mike (04-01-2011)
Old 04-01-2011, 07:35 PM   #15
new Roof
Whether he is reputable or not, I always like to become somewhat informed as to what is being done to my home, car, etc. It does not hurt for me to pick the ears of experts. No different than people doing so with me.
Mike
The Following 3 Users Say Thank You to kiropod For This Useful Post:
kwikfishron (04-01-2011), MJW (04-01-2011), Roofmaster417 (04-01-2011)
Advice needed! New roof half-installed and it's raining! blue68 Roofing/Siding 4 03-29-2011 10:52 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
Flat roof repair/replacement questions zmt Roofing/Siding 4 02-23-2010 12:24 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
Extend House Roof Over Back Deck Justahome Carpentry 17 04-05-2009 04:42 PM
