New Roof - Need Help With Color Please - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-10-2013, 12:52 PM   #1
New Roof - Need Help with Color Please
I'm in contract to have a new roof installed within the next couple of weeks and need to pick a color asap. I've been back and forth with which one to use. I think I've narrowed it down to Owens Corning Trudefinition Teak and Certainteed Landmark Heather Blend. It's been a long and difficult decision because everything tends to clash with the brick (and I don't want to paint it).
We will be changing the storm door to brown, replacing the skylight, adding copper flashing around the chimney and extending the overboard extension and gable by 10" to allow for recessed lighting to be installed in the soffit.
Please let me know if the picture of my house with Trudefinition Teak is too dark, too busy, etc? Is it an improvement compared to what I have now? I don't think I set-up the spacing of the shingles in the mock-up photo so I can't tell what it will look like for sure.
Unforunately, I can't figure out how to link the Certainteed Heather Blend picture of my house that I did on Certaineed's Colorview site. I've added a swatch of the shingle to help you visualize it. It looks softer than the Teak, but I don't know if it has too much gray in it.
I'm also open to other color suggestions. But believe me, I've tried them all in mock-up pictures and pretty much everything looked horrible, except for these two.
Thanks!
My House Now -
Owens Corning Trudefinition - Teak
Certainteed Landmark - Heather Blend
AdviceWanted is offline   Reply With Quote
Old 05-10-2013, 08:06 PM   #2
Here's some more pictures to choose from:
Landmark Solaris Sunset Shake
Landmark Burnt Sienna
Old 05-10-2013, 08:39 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
one vote for Landmark Heather Blend
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
r0ckstarr (05-11-2013)
Old 05-10-2013, 10:09 PM   #4
Roofmaster
Rewards Points: 2,210
Let your wife pick or you will never hear the end of it. Shingle: Landmarks
The Following User Says Thank You to jagans For This Useful Post:
GBrackins (05-10-2013)
Old 05-11-2013, 07:06 AM   #5
Rewards Points: 14,312
Please go back and add your location to your profile, dark shingles in a hot location will over heat the up stairs.
Just go to Quick links to edit.
Also if the door side of the house is in the direct sun it's a huge mistake to paint that door a dark color.
With that type storm door you'll have a solor panel and it can distroy the inside door.
Any new door will come with a sticker on it with this warning.
Old 05-15-2013, 07:31 PM   #6
Rewards Points: 2,652
Sunset Shake. The others are too dark.
SPS-1 is online now   Reply With Quote
Old 05-15-2013, 09:09 PM   #7
747
registered
747's Avatar
Rewards Points: 534
landmark mission brown if available in your area. I'm not sure what color pallet is available in your area. I'm central.
ps. Your neighbor on the left has gaf timberlines.
747 is offline   Reply With Quote
Old 05-15-2013, 09:45 PM   #8
If you can get them look into landmark resawn shake
But stick with certainteed, what ever color you pick.
jsbuilders is offline   Reply With Quote
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Tell me about roof coatings for an older roof Leica Roofing/Siding 3 09-19-2010 01:55 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
