New Roof - Nails Pushing Shingles Up - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-06-2011, 02:52 PM   #1
Rewards Points: 206
Question
New roof - nails pushing shingles up
Just had a new asphalt shingle roof put on my house.
In general, they did an excellent job.
My only concern is in some places (10 or 20) a nail wasn't driven in fully, and it's pooching up the shingle above it a little bit.
All the old material was removed first. Then new 30 lb felt and new shingles installed. The roofer used 7/8 inch roofing nails, applied with a hammer, because he said a nail or staple gun, on my 1x6 tongue and groove sheathing, would shower splinters into the attic.
Should I ask the roofer to come back and 'fix' the nail bumps?
John_W is offline   Reply With Quote
Old 11-06-2011, 03:07 PM   #2
Rewards Points: 268
yes...
packer_rich is offline   Reply With Quote
Old 11-06-2011, 03:19 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,286
Yes.
Should only take a few minutes to address those items in question.
Old 11-06-2011, 03:31 PM   #4
Rewards Points: 206
Originally Posted by Windows on Wash View Post
Yes.
I have only seen these bumps on the north side of the roof. I suspect there are similar bumps on the other parts of the roof. Probably the way the sun hits the roof makes the ones on the north side easier too see.
Can a pro find similar bumps on the other faces of the roof where the light is not as favorable?
Old 11-06-2011, 04:43 PM   #5
Things should be more visible from the roof deck and with the right lighting, I am sure your roofer will see what needs to be seen.
The Following User Says Thank You to Windows on Wash For This Useful Post:
John_W (11-06-2011)
Old 11-06-2011, 05:05 PM   #6
MJW
Nails are to penetrate 3/4" into 1x planking.
Sounds like a Carpenter, not a roofer. JMO
MJW is offline   Reply With Quote
Old 11-07-2011, 06:47 PM   #7
nailing shingles now a days involves only pulling a trigger, gone are the days of continually inspecting your work. God forbid you ever have to use your hammer
framingrailman is offline   Reply With Quote
Old 11-07-2011, 10:02 PM   #8
Rewards Points: 206
Here is a picture of the nails they used. Since they are loose, I thought they must have been put in with a 'manual' hammer.
Old 11-08-2011, 04:08 AM   #9
Rewards Points: 2,238
"John W"
As the roof heats up and the shingles "settle down" -
You'll probably, see more -
Look at the ridge/hips.
Possibly, "angled" nails.
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
John_W (11-09-2011)
Old 11-08-2011, 05:11 AM   #10
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Those nails are only suitable for felt. Shingle nails, placed in their correct places must be HDD roofing nails. The EG pictured there will rust away in no time if properly placed.
You'll see more when they warm up and soften some more.
tinner666 is offline   Reply With Quote
Old 11-08-2011, 10:39 AM   #11
Rewards Points: 206
Thanks for that info.
Here is a picture that shows what looks like two boxes of nails - one with a red lid and one with a blue or clear lid. So, maybe they used the nails from the box with the red lid for the shingles.
They did the job in three days, with a three man crew (2,500 square foot, single story house). Each day they did 1/3 of the roof, leaving the other parts untouched till the next day. So, they would have done everything from demolition to new shingles each day, on the 1/3 roof they were working.
This company has a spotless reputation with the BBB (no complaints in last three years), they do roofing for our painter (on his rental houses) and they did a nice job on the roof on our neighbor's house last year. They have been in business here for many years.
They are coming out to investigate the nail bump issue this week and "take care of it".
Old 11-08-2011, 12:10 PM   #12
Next Time...New Build
Rewards Points: 150
I think Framingrailman was just making an observation on how nowadays speed can sometimes trump quality. Yes, your shingles were hand nailed with a hammer/roofing hatchet.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
framingrailman (11-08-2011)
Mteal roof over existing shingles Mark Harvey Roofing/Siding 1 08-24-2011 01:20 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Need new Roof Shingles larrylwill Roofing/Siding 5 12-16-2009 10:26 AM
Improperly installed roof ktpersh Roofing/Siding 1 05-15-2008 06:57 PM
