New Roof Leaks...questions. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-28-2011, 01:00 PM   #1
Rewards Points: 171
New roof leaks...questions.
Hello,
I purchased my first home about 6 months ago and have logged on to this forum numerous times to find answers about projects that I have pursued so far. Very helpful place this has been.
About 3 weeks ago I had a new roof put on, and have dealt with leaks in two spots so far. One spot was due to flashing that was done improperly, and has since been corrected by the roofer.
I don't have a great feeling about the other leak though. The leak in question occurs on a flat part of the roof above a room that was added onto the back of the garage for extra storage. I speculate that the leak is happening because water is seeping back beneath the shingles since there is very little slope in this section of the roof.
I'm starting to question the roofer's decision to use shingles on this part of the roof. We agreed that he'd fix all leaks before I pay the rest of what I owe him for the job. Would it be reasonable for me to ask that he re-does this portion of the roof with a rubber membrane or some other low-pitch material, at no extra charge? The flat portion of the roof is relatively small, approximately 8' by 8', so it shouldn't be big undertaking for him to do it. On the other hand, I'm pretty sure this guy has actually lost money on this job by coming back numerous times to inspect and fix the flashing, and because he accidentally ordered architectural shingles for my roof instead of 3-tab and did not charge me for the price difference.
Thoughts?
MrBryan is offline   Reply With Quote
Old 04-28-2011, 01:07 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Originally Posted by MrBryan View Post
Hello,
Thoughts?
If the roof was a lower slope than what is allowed on the product he installed, then he shouldn't have installed them to begin with. If the material is installed to specs, then the leak is a workmanship issue.
It's not your fault that he's lost money because he ordered the wrong materials or didn't flash something properly. He needs to make it right.
seeyou is offline   Reply With Quote
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
3 season room roof leaks rod altman Carpentry 7 12-22-2010 09:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
questions about wood shake roof oraph Roofing/Siding 4 10-26-2006 05:10 AM
