Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-15-2009, 06:54 AM   #1
New roof leaking.
I am building a shed under my deck. Got the roof installed and put it into position. Got a heavy rain last night and it leaks. I have a slope of about 6 total. Thats about all I can do The inside wall is 90 inches high and the outside is 84 inches high. This may not be enough of a slope but that is all I can really do. I figured if it was under the deck it wouldn't get hit so hard. Well I was wrong. I will be taking out the wall to see what I can do to fix this problem. I was thinking of putting plastic corragated sheets on top to give it more protection. Any ideas. Iused tar paper and roofing shingles.
stevez is offline   Reply With Quote
Old 05-17-2009, 05:28 PM   #2
New roof leaking.
Shingles are not used in a roof pitch less then 3 in 12. That's a 3" drop over 12" of horizontal run. The phase, "I have a slope of about 6 total", doesn't reveal the actual roof pitch. What's the distance from ridge line to the fascia board?
There might be other issues with the roof. Why don't you post a picture?
Ron
Old 05-18-2009, 01:01 PM   #3
New roof leaking.
Gaf/Elk Timberline shingles go down to a 2/12 pitch but that still may not suit your needs.
Ice & water sheild would probably work fine as an underlayment (after all it is only a shed)
You do need to let us know what the horizontal length is from the exterior wall to the ridge
Dale Chomechko
Dc Roofing Inc
Dale Chomechko is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing 22 09-14-2012 01:19 AM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing 5 01-06-2009 07:51 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
