New Roof Installation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-30-2010, 01:18 PM   #1
Rewards Points: 109
new roof installation
I live in NY state , how late in the year do you think a new roof could be installed on my garage as far as the temperature and the shingles sealing properly?
hitmehhh is offline   Reply With Quote
Old 10-30-2010, 03:12 PM   #2
MJW
As long as it's not in a dusty area and you do a good job with good materials, you can put shingles on in almost any temp. We have put on many roofs below freezing temps (some below 0 F) and haven't had a problem. The shingles will seal the next sunny warm day.
The guys slamming in many roofs a week usually don't work in the cooler temps. Too many problems. Plus their labor usually heads back south.
MJW is offline   Reply With Quote
Old 10-30-2010, 04:44 PM   #3
RoofDiagnostics's Avatar
Re: new roof installation
The optimal temp range is above 40degrees... If you are below 40, you can still install but make sure to store materials inside before the installation.
Installing the ice/water shield is a good indicator whether or not you are having a problem. If it sticks, you are good.... If it doesn't you may have an issue.
Hope this helps.
PS. The 40 degree # is recommended by GAF... Personally, I think the number is closer to 30
RoofDiagnostics is offline   Reply With Quote
Old 10-30-2010, 09:11 PM   #4
Rewards Points: 978
it was pretty cold the morning they started on my roof. i would say around 40. but it warmed up to like 65 by 11am
federer is offline   Reply With Quote
Old 10-30-2010, 10:12 PM   #5
Remodeling Contractor
I live in Minnesota. Brutal winters here. I have installed hundreds, if not closer to 1000 roofs in the winter months. I have honestly never had a problem shingling when it is cold. You just have to watch air pressure for your nailers so your nails aren't setting too deep and blowing through the shingles.
eisert is offline   Reply With Quote
EPDM Roof Plans stubits Roofing/Siding 44 04-30-2010 11:06 PM
Need some help with roof - NO clue what to do, or how.. :( AdrianVall Roofing/Siding 7 04-22-2010 08:32 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
Tile+Asphalt Roll Roof leaking - Opinion on what to do brookbphx Roofing/Siding 5 01-06-2009 06:51 AM
