New Roof Install Shingles Are Cupped. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-18-2011, 09:56 AM   #1
New roof install shingles are cupped.
My new roofing shingles were installed last week. I noticed that a dozen or more shingles are cupped. By cupped I mean that they are up on the bottom edge like they have been pulled down on both ends, if that makes any sense. My contractor said that they would lay down when it gets hot next summer. My roof pitch is 12/12 and the roofers didn't use walk boards, just ropes to hang on to. Seems to me the shingles should be flat to begin with. Does anyone have any ideas as to what could cause this and what is the remedy The shingles are Owens Corning dimension. Thanks
rled is offline   Reply With Quote
Old 11-18-2011, 11:33 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,184
They are going to need some warm weather to lay flat and seal themselves to the course below. What was the temp when they put them down and since they have been down.
Make sure your roofer is willing to warranty wind blow off between now and when they seal themselves.
Old 11-18-2011, 11:34 AM   #3
Gymschu's Avatar
Rewards Points: 668
I would post a pic so the expert roofers on here can fully answer your question. From my perspective as a DIYer, depending on how cold the weather is in your location, it could take some time for the sun to warm the roof, make your shingles pliable, and allow them to lay flat as they are supposed to. This is not uncommon and since it's only a "dozen or so" your roof will be fine.
Old 11-19-2011, 11:45 AM   #4
cupped shingles
I will take some pictures and post them tomorrow. Thanks
Old 11-22-2011, 10:37 AM   #5
cupped shingles
Here are some pictures of the new roof job. The temperature was around 70 degrees when the shingles were put on. It was 2 weeks today when they were installed.
New roof install shingles are cupped.-roof-shingles.jpg   New roof install shingles are cupped.-cupped-shingle.jpg
Old 11-22-2011, 11:08 AM   #6
Another pic of roof.
Here is another view of the roof.
Old 11-22-2011, 11:40 AM   #7
They appear to be mostly shingle issues and are likely the units that were left on top of the ridge for too long.
They should lay down after a bit.
Old 11-22-2011, 12:29 PM   #8
Rewards Points: 2,238
What "W on W" says.
70 degrees.
You may have to wait for the for the shingles to "lay down".
If they don't do it by the "spring time" -
could be shingles not nailed securely.
Tilted nails -nails not driven "home".
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Windows on Wash (11-22-2011)
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Mteal roof over existing shingles Mark Harvey Roofing/Siding 1 08-24-2011 01:20 PM
EPDM roof install questions SoxFan44 Roofing/Siding 2 08-23-2011 07:00 AM
Improperly installed roof ktpersh Roofing/Siding 1 05-15-2008 06:57 PM
