New Roof And Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-15-2009, 03:34 PM   #1
new roof and gutters
Should the new roof be put on before the new gutters or gutters first?
Dennis5150 is offline   Reply With Quote
Old 10-15-2009, 05:05 PM   #2
Residential Roofer
Slyfox's Avatar
Roof first than gutters.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 10-15-2009, 05:53 PM   #3
Metalman
Ok well thats probably a roofer, so as a metal man I will tell you even if it is a residential roof, make sure your roofer doesn't pull the dripedge as tight as they can to the fascia. That way the gutter guy "continuos residential I am guessing" wont have to pull out the face of the dripedge, because they will and it will look like ****. If it is a commercial job then do not let the roofer apply the drip/gravel first. It is a nightmare to apply comm. gutter afterwards, and you will pay for it. At least you can push the res. gutter nails through the face of the drip.
SemperFi is offline   Reply With Quote
Old 10-16-2009, 07:00 AM   #4
Residential Roofer
Slyfox's Avatar
So, Roof or Gutters first?
I also assumed the poster was speaking of residential which is why I said roof first. He did not ask how so I simply gave a direct and simple answer.
I have never installed the roof first and gutters second on commercial grade work that required gravel stop, that's entirely different scope of details.
Facebook <> Twitter
Old 10-16-2009, 08:22 AM   #5
CCCo.
CCCo.'s Avatar
Location: Kirklin, IN "Proudly Serving Central Indiana"
Simple,
Remove the old roof, old drip edge, and the old guttering, install the new drip edge, new roof, then install the new guttering.
Same process you'll see on any construction site.
Anything less is just bad advice, period.
Crow Contracting Company - - - www.crowcontractingco.com - - - www.indianaremodelingcontractor.com
Remodeling Contractor - North Central Indiana, Indianapolis, Noblesville, Carmel, Fishers, Zionsville, Westfield, Lebanon, Whitestown, Brownsburg, Sheridan, Tipton (765) 279-8271
CCCo. is offline   Reply With Quote
Old 10-16-2009, 09:40 AM   #6
Sorry I didn't mention it but, yes it is residential standard hip. I am not sure what drip edge is. I assume it is a L shaped metal flashing that has one edge that slides under the first (starter) course of shingles and the other into the gutter? right or wrong??? I need to get as smart about roofing as I can because next spring/summer I will be having a 2 layer tear off and new roof and gutters installed and want to fully understand what the contractor is doing, and that he is doing it right. I am sure I will have more questions. Thanks for the help.
Old 10-16-2009, 09:46 AM   #7
Licensed Builder
Handyservices's Avatar
That sounds correct. The purpose of the drip edge is for water to run into the gutter; not behind it - causing water infiltration and damage.
Handyservices is offline   Reply With Quote
Old 10-16-2009, 01:55 PM   #8
No he wasnt too specific at first. I have had the misfortune to hang commercial gutter either replacing old or not getting the job organized properly with the roofer, and it sucks. However I am just glad to hear he has a roofer, I thought he was going to say, next spring/summer I will be putting this roof on. Like the prior owner did to my house, what a nightmare.
New roof: GAF v ShingleVent II, warranty, gutters? soubriquet Roofing/Siding 8 08-01-2010 10:17 PM
Concrete roof on house... problems!! flipjarg Roofing/Siding 6 01-24-2009 10:06 PM
Replacing roof but keeping old gutters JJB Roofing/Siding 2 07-29-2008 05:29 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 09:36 PM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 04:33 AM
