#1 |
new roof - code requirements & quotes
Hello everyone... hope you can give me some advice. Looks like the ins. co. says new roof, and I'm getting some quotes. 1400 sq ft, 25+ years old (South FL). First says I absolutely need single wraps and second water barrier, second guy didn't even mention it. What I'm wondering, is it necessary to have the wraps installed, and maybe what is a fair price for this size house. Also, lower quote says he uses Tamco Heritage Premium vs, first quote 25 yr GAF... what do you all think?
Thanks in advance... |
#2 |
Average Joe/ex-Navy IC3
Go with the best your money can afford. We ended up going with GAF's Elk shingles, due to they have on the bottom edge the tar, vs at the top edge as conventional shingles have. With the high winds we get here in Illinois, we have not had any problems with lift or deterioration of the shingle.
Ice and rain shield is a must. There is now a newer product that took the place of felt paper, that acts as a rain shield, and can stand up to severe weather.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| Display Modes | |
| Code requirements for neutral conductor in a NEMA 14 receptacle? | flasherz | Electrical | 2 | 10-02-2012 10:59 AM |
| Proper transition between shed roof and shingled roof? | aribert | Roofing/Siding | 9 | 04-12-2012 04:17 PM |
| rubber roof over tar & thoughts on quote | wfmrules3 | Roofing/Siding | 13 | 10-16-2011 10:00 PM |
| Carport Lean to Roof Question.. | jgcable | Building & Construction | 31 | 04-29-2011 06:12 PM |
| Roof leak nightmare..... it won't stop | amandat37 | Roofing/Siding | 52 | 04-22-2011 01:47 PM |
