New Roof And Chimney Repoint - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2011, 04:16 PM   #1
New roof and chimney repoint
I'm about to replace the roof on my house -- removing existing shingles, installing new 5/8" CDX decking (bottom layer appears to be wood shingles), add/cover fascia boards, replace gutters and soffits, etc. One of the roofing contractor companies is saying that they will re-point the chimney. According to the person who came out for the estimate it is a matter of using a wire brush to scrape off any loose mortar and then putting new mortar as if icing a cake. The chimney is used for the exhaust on a gas boiler and water heater only. Hopefully you can see the pics of the chimney. I'm hoping to get your sense of whether re-pointing is a good idea. Frankly I had never given the chimney much thought before. By the way, this contractor is about $800 more than the next guy, so in essence that's how much the re-pointing will cost me as the other bids are all similar in cost and work to be done. Thanks in advance.
clhernandez is offline   Reply With Quote
Roof leak near chimney GlennAble Roofing/Siding 23 07-22-2011 06:52 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 06:24 PM
chimney spalling - replace, repoint, cover, other? abieslas Roofing/Siding 6 08-21-2009 01:39 PM
Heading off roof rafters for chimney pipe. jrcurto Carpentry 4 10-29-2008 12:25 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
