New Roof And Chimney Refacing With Stone Veneer - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-12-2011, 06:33 PM   #1
new roof and chimney refacing with stone veneer
I am having a new roof installed as well as refacing my chimney with stone veneer. What should be done first? Should the chimney be completed before the new roof is installed or should I have the chimney refaced with ledgestone veneer before the roof is done?
rfrf is offline   Reply With Quote
Old 09-15-2011, 10:01 PM   #2
The roof 1st in my opinion.
But, I would also include the mason contractor to install a suitable and acceptable pre-fitted Counter-Flashing to exend below the bottom course of stone veneer so that the 1st and succeeding roofing contractors working on the roof could install the originasl and future sheet metal flashing kits without having to consider flashing to the bumpy exterior surface of the stone veneer product.
Ed
Ed the Roofer is offline   Reply With Quote
The Following User Says Thank You to Ed the Roofer For This Useful Post:
concretemasonry (09-16-2011)
Old 09-15-2011, 10:37 PM   #3
Concrete & Masonry
Rewards Points: 636
Pretty sure every mason you run into is going to want to do the chimney first, due to the amount of mess that can occur with the mortar. Additionally, laying drop clothes/tarps on the roof may protect the shingles, but it's not the safest situation for the masons to work on. Not to mention the potential shingle damage that can occur from the rebuild.
jomama45 is offline   Reply With Quote
Old 09-15-2011, 11:06 PM   #4
See, thats what you get when a mason responds, LOL.
Roofers say roof 1st.
Hmmm??? What to do now???
Ed
The Following 2 Users Say Thank You to Ed the Roofer For This Useful Post:
concretemasonry (09-16-2011), jomama45 (09-16-2011)
Roof leak near chimney GlennAble Roofing/Siding 23 07-22-2011 06:52 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 06:24 PM
Roof fans sucking air through chimney? Badfish740 HVAC 8 10-08-2008 10:01 AM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
