New Roof, Adding Penetrations? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-28-2012, 07:52 AM   #1
Rewards Points: 502
new roof, adding penetrations?
Not sure were this should go, here, bathrooms or plumbing, but I decided to go with roofing.
I am getting a new roof in the very near future Most likely a "cheap" steel roof.
It dawned on me, that this would be the time to add a bathroom vent. Do I run it straight up through the roof? up to the peak? or over to a wall and keep the roof completely un-pierced?
I am also contemplating a new sewer vent. the current one is up through the inside edge of an outside basement stair roof, and under the eave of the main roof. I will probably redo the whole sewer system when I redo the bathroom down the road, so I could move it now with a few inconvenient junctions in the basement, until I redo it all. If I go with 2 roof penetrations, should they be in-line? far apart?
forresth is offline   Reply With Quote
Old 07-28-2012, 02:09 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Bathroom vent can go through the the gable end.
Plumbing vent should go through the roof.
The Following User Says Thank You to Windows on Wash For This Useful Post:
mae-ling (07-28-2012)
adding roof to existing deck sgh36 Building & Construction 3 06-05-2012 07:34 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Roof Penetrations in flat roof for lineset/whip mrc333 HVAC 1 03-09-2012 01:30 PM
Adding roof overhang before new shingles Kathompson Roofing/Siding 1 09-03-2011 06:22 PM
Adding foam board insulation & plywood to underside of roof sheslostcontrol Insulation 1 05-04-2011 07:08 PM
