Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-11-2012, 07:43 AM   #1
New Roof
Recently had new roof put on.
Complete rip off and replacement with shingles and torch down on porch area. Contractor put drip/angle all around roof on the porch on top of TD then used tar/cement over that. Question should drip/angle be installed under TD ? If so how would the finished edge of the TD be finished? Having problem with Photos will post if I can.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-11-2012, 08:35 AM   #2
Roofmaster
New Roof
The nailing flange of the metal should be primed on both sides with D-41 primer. Modified roof cement then applied to the edge, and the metal set in cement. The metal is then stripped in with an 8 inch wide strip of mod bit while torching back of mod bit and metal. ALternately, do as above, then top coat metal and 4 inches out onto roof surface with modified cement. Embed 6 inch asphalt saturated cotton fabric, trowel in and top coat with modified cement. After set, aluminum coat roof and flashing.
It is always good to install a tapered edge right at a drip edge because you end up building up the edge there, and this will cause ponding right behind the build up. This requires covering the roof with 1.5 inch rigid insulation and a mechanically fastened G2 Base sheet though, which costs more.
The Following User Says Thank You to jagans For This Useful Post:
COLDIRON (12-11-2012)
Proper transition between shed roof and shingled roof? aribert Roofing 9 04-12-2012 04:17 PM
Flat roof and insulation quandry paredown Roofing 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing 15 11-07-2009 06:48 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing 3 11-06-2009 10:07 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
