New Member Here, I Have A Concern About New Chimney Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-13-2013, 05:07 PM   #16
Metal Roofing
Rewards Points: 600
wow that is ugly, incorrect and it leaks. You got yourself a triple jackpot there.
AndyWRS is offline   Reply With Quote
Old 01-13-2013, 05:09 PM   #17
thanks.........
Peter683 is offline   Reply With Quote
Old 01-13-2013, 05:33 PM   #18
Rewards Points: 2,240
There's a lot of "roofers" around here, that flash chimneys that way -
As pointed out above - sure hope they used step-flashing!
rossfingal is offline   Reply With Quote
Old 01-13-2013, 05:36 PM   #19
Well, looking at other houses this afternoon on a drive around the city, we can't see anything like this...?
We haven't had much in the way of rain until this week..
Old 01-13-2013, 05:42 PM   #20
Don't worry !!
The more you start looking at chimney-flashing -
the more you'll start to see!
(Ha, ha, ha! - join the club!)
Old 01-13-2013, 05:43 PM   #21
The only other flashing I want to admire is the correct on on the house !
Old 01-13-2013, 05:53 PM   #22
Find somebody that knows what they're doing.
Hey! -
"Roofmaster417" -
why don't you take a quick "road-trip" up north and give this person some guidance!?!
Old 01-13-2013, 05:56 PM   #23
Roofmaster
Rewards Points: 2,210
No it does not work.
The base flashing is nailed to the roof deck in the upper outer corner with two nails through ice dams flashing. The base flashing is NEVER attached to the chimney. The counter flashing which comes down over the base flashing is NEVER attached to the base flashing WHY?
Because when the chimney gets hot it expands in two planes. Up (Tension)
and sideways (Shear). The base flashing under the counter flashing must be free floating to allow this.
Surface mounting to Brick, especially porous brick is as worthless as a tit on a bull. The best counter flashing is that which is set by the mason fully through the mortar joint, and turned up behind the brick. The best material, Arguably, is 20 oz. Lead coated Copper. Cutting into a joint is often the best you can do when a real through brick flashing was not set, which is pretty much the norm in this day of slap it up and run.
Please, Please, Mister Roof Man! What if my kids go up on the roof and suck on my counter flashing? They will suffer Brain Damage from lead poisoning!!! Dats OK Lady, as soon as day are teenagers, day will be sniffin glue anyway!
Joe, since the back of their chimney is at the ridge, they don't need a cricket. AN apron back there will work too. But I Agree if it was down slope.
Old 01-13-2013, 06:33 PM   #24
"OP" -
Tear down the chimney and try to find some bricklayers/masons that
know what they're doing with flashing - good luck with that!
(Kidding!)
Find somebody that has a "clue" about flashing roof, penetrations.
Old 01-13-2013, 06:36 PM   #25
Originally Posted by rossfingal View Post
"OP" -
(Kidding!)
Yeah the first part of that post isn't gonna happen,, actually the chimney itself is in great shape!
Old 01-13-2013, 06:46 PM   #26
That's good! (That the chimney is in good shape!)
Then, find someone who knows how to do flashing -
have them take a look at it.
Myself - I would tear off the counter-flashing and see "exactly", what
was done with the step-flashing -
(If they even put in step-flashing!)
It's a bad sign to look up from the attic and see day-light!
Good luck!
rossfingal
(We await an update!)
Old 01-13-2013, 06:49 PM   #27
Will keep everyone updated and thanks for the help and advice so far!
The Following User Says Thank You to Peter683 For This Useful Post:
rossfingal (01-13-2013)
Old 01-13-2013, 07:01 PM   #28
You're welcome!
Stop back anytime!
"RF"
Old 01-13-2013, 07:52 PM   #29
Roofmaster
The guy that flashed this did not saw cut your bricks on an angle did he?
Old 01-13-2013, 08:07 PM   #30
Don't see no "over-cuts" on the bottom bricks -
so, probably not.
Roof Flashing around Chimney blackharvick Roofing/Siding 3 11-03-2010 08:35 PM
Chimney peak flashing richbl Roofing/Siding 5 09-29-2009 05:23 PM
Chimney flashing plus "hot mopping"? gante Building & Construction 4 03-25-2009 10:49 AM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 10:27 AM
Roof leaking by Chimney, No Flashing twilightcall Roofing/Siding 2 07-30-2008 04:40 PM
