New Insulation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 09:41 PM   #1
Rewards Points: 1,088
New Insulation
Itch free, but is it better? Seems like it has a greater R value/inch compared to both fiberglass and cellulose.
http://building.dow.com/na/en/produc.../safetouch.htm
handy man88 is offline   Reply With Quote
Old 11-06-2010, 09:47 PM   #2
I see the same Rvalues...R13, R19 & R30 are all the same
There is also an R22 for a 6" wall in fiberglass.....
....link is only rated at R21
Old 11-06-2010, 10:16 PM   #3
If you talk to the insulation companies, its not the fiberglass thats itchy its the glue that holds it together.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 11-06-2010, 10:20 PM   #4
I thought fiberglass has about 2.5R/inch, with cellulose about 3.5R/inch. With this new stuff, it's about 3.7R/inch.
Old 11-07-2010, 12:34 AM   #5
Rewards Points: 780
I bought a bundle of this stuff Handy man88.
It's good stuff...... but.
Cutting it is so difficult. I tried laying a 2x4 over it and cutting it with a utility knife - fresh blade. That was a nightmare. After about an inch or so into the cut, the fibers start dragging with the knife and it's a mess.
So I tried cutting it with a pair of scissors. That wasn't a lot better because scissors won't cut through the full thickness of the batt, so you have to make several passes.
If there's a better way to cut it, I'd buy it again for sure. It seems like really nice stuff - so much better than working with fiberglass.
The plastic backing on it peeled off very nicely if you don't need the vapor barrier.
I didn't try hanging any of it up in a wall. I was using it to fill gaps.
It's sold in bundles of 4' (?) batts, so it's possible that you may not have to cut very much of it anyway.
Have you tried Roxul insulation? That's supposed to be the best insulation to work with.
gma2rjc is offline   Reply With Quote
Old 11-07-2010, 07:17 AM   #6
roxul is great stuff give that a try.
Old 11-07-2010, 07:51 AM   #7
What the heck? Sounds like Kevlar.
I had Johns Manville white fiberglass blown in earlier this year, so I won't be needing this new stuff. I just thought I'd report this new product I saw advertised on tv.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
