New House, Ridge Vents And No Soffits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-18-2010, 01:44 PM   #1
New house, ridge vents and no soffits
We just got a new/old (1946) house that has just had a new roof installed with ridge vents. Only issue I see is that there is absolutely no other attic ventilation other than the ridge vents. Obviously I need to add soffit vents or something. Not sure what that something might be. The
This house also has very short eaves. The soffits are currently some old fiber siding of some sort that has rotted in several places and I have considered replacing all of them with the Hardy board that has the vent holes in it. Seems like a reasonable solution to solve two problems.
Any other thoughts? This is in Midland Tx, HOT summers, 99% direct sun and mild winters.
arlon is offline   Reply With Quote
Old 05-19-2010, 11:31 AM   #2
Rewards Points: 1,498
Just be sure that the soffit area is clear up into the attic and you reposition any insulation at the soffits so air can flow through freely.
AllanJ is online now   Reply With Quote
Old 05-19-2010, 09:47 PM   #3
Registered User
Rewards Points: 5,492
http://www.dciproducts.com/html/smartvent.htm OR: http://www.cor-a-vent.com/PDF/S4002P.pdf
Be sure to install a balanced system: http://www.airvent.com/homeowner/pro...it-specs.shtml http://www.fureyco.com/content/image...ng_The_Air.pdf
Be safe, Gary
Old 05-20-2010, 08:05 AM   #4
I really like the continuous soffet vent. That looks like a relatively easy installation. Considering how the roof was done, I'm not even sure the ridge vents are functional. I can see they are up there but I haven't gotten into the attic to see how they where installed. Thanks for the link.
Now I have something to go by. I see I need to measure how many feet of ridge vent I have and see how that compares to the sq ft of the house. I'm thinking the ridge vents aren't going to be enough on the exhaust end.
Thanks agin for the links and information.
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 09:48 PM
Warm and cold air only coming out of 4 vents in whole house petergreen HVAC 5 02-03-2010 03:54 PM
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 07:12 AM
I am ready to get rid of the ridge vents PerpetuallyRepairing Roofing/Siding 20 04-15-2009 09:17 AM
Attic Insulation - Current R Value? jamiedolan HVAC 37 01-01-2009 11:03 AM
