Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-15-2013, 09:00 PM   #1
New Home, New Roof
Ok so I bought my dream home 4 months ago and was told by a roofer yesterday that I need an entire roof. I called to have my porch roof looke at and an estimate given and he turns around and says my entire roof is bad.
lnowakowski is offline   Reply With Quote
Old 02-15-2013, 09:08 PM   #2
New Home, New Roof
Gee that's to bad.
Now is there a reason your sharing this bad news with us?
Is there a question?
Got some pictures, a report the guy gave you stating why it needs replacing?
Old 02-15-2013, 09:26 PM   #3
747
registered
747's Avatar
New Home, New Roof
Double post.
747 is online now   Reply With Quote
Old 02-15-2013, 09:29 PM   #4
747
registered
747's Avatar
New Home, New Roof
Sorry to hear this. Depending on the square footage of the roof(roofer square) you can expect to drop 6,000-10,000. Hopefully not more. Get several bids. Go to certainteed's website see if there is a certified roofer in your area. Make sure you get a bid from him.
If it makes you feel any better. When i had a new roof put on my house 3 years ago. The whole roof needed to be re sheathed. 82 sheets. I went with osb at 30 installed. Even though i like 1/2 inch cdx. Which was 50.
Old 02-15-2013, 10:24 PM   #5
Gymschu's Avatar
New Home, New Roof
A home inspection should have caught this........you did have a home inspection?
Old 02-16-2013, 06:47 PM   #6
Metal Roofing
New Home, New Roof
Get a second or even third opinion, your roofer may have been trying to scam you into a new roof.
Dreams were made to be broken...or is that rules i forget
Keep positive, get some other opinions on the roof so you have a clear idea if your having your chain pulled. Only then can you offically panic.
AndyWRS is offline   Reply With Quote
Old 02-19-2013, 04:58 PM   #7
New Home, New Roof
I feel your pain. Our inspector was not physically able to access the crawlspace in the attic. After moving in and our first big rain, I went in the attic and noticed numerous leaks (30 year old monier tile w/o subroof). With the obvious rot and water stains, it didn't take a roofer to notice there was a problem. We look at the inspection report and wouldn't you know it, there are disclaimers all over for each section of the inspection. Why do we hire these people?
$13k lesson. Papa always said, "just make sure the roof don't leak," and I failed.
Sorry, had to rant...
bee-man is offline   Reply With Quote
mobile home deck roof attaching wyomingguy Carpentry 3 08-28-2011 06:07 PM
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
mobile home related metal roof insulation chris313scorpio Building & Construction 0 09-28-2010 10:29 AM
venting from mobile home through new metal roof jeanmoon Roofing 2 07-27-2010 09:39 PM
metal roof on m0bile home hoodrunner365 Roofing 3 02-10-2010 02:20 AM
