Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-23-2011, 01:45 PM   #1
New Flat Roof Cracking within 2 weeks
I just had my roof redone, about 1000 sqft worth. It hasn't even been two weeks yet, and I notice a large portion of it is starting to crack all over. Its the painted reflective coat. What can be causing this? It almost looks like the portion that is cracking is a totally different paint material, so I've ruled out temperature expansion/contraction because it would have been the entire roof.
The materials used were:
Gaf Gafglas 75# Base Sheet (Asphalt-Coated Glass Mat)
Gaf Ruberoid Smooth Torch
Apoc 211 Liquid Silver-NF Non-Fibered Aluminum Roof Coating
Pictures here:
http://www.flickr.com/photos/6207405...7626560372806/
acerunner is offline   Reply With Quote
Old 04-23-2011, 02:25 PM   #2
NACE Coating Inspector
mustangmike3789's Avatar
all coatings fail over time. 75% of all premature failures are due to surface preparation. this looks to be alligatoring due to too thick of coating applied at too high of a surface temperature. also with the different color variations i would have to beleive that the coating was not mixed properly or sufficiently. according to the product data sheets for this coating, mixing should be done during application to keep solids/pigments suspended. this coating should probably be removed and applied at a lesser thickness and applied with a lower surface temperature. check with the manufacture for a possible fix such as applying a hotter solvent to dissolve the existing coating for thinning it out.
mustangmike3789 is offline   Reply With Quote
Replacing peaked roof with a flat roof....? earthtoned Building & Construction 2 01-21-2010 05:28 PM
Blown Insulation - Flat roof AndrewF Roofing 1 12-31-2009 07:41 PM
Flat roof related questions christy123 Roofing 8 12-10-2008 12:30 AM
large leaking tar flat roof erbilliards Roofing 2 03-16-2008 12:59 PM
Where flat roof meets shingled roof bstyer Roofing 1 07-07-2005 09:34 PM
