New Construction - Warped Wood - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-05-2012, 02:30 PM   #1
New construction - warped wood
We've just had a new home built and discovered warped beams of wood in the attic. These beams run perpendicular to the floor and are connected to the sloping roof beams along both sides of the attic.
Instead of replacing the wood - or even explaining why the beams are warped - our builder cut 2x4's and wedged the pieces between the warped beams. In the process, some of the beams split near the bottom. Plus, the 2x4's aren't even flush with the beams.
The builder insists there will be no structural issues, but an independent inspector we hired (who pointed out the warped beams in the first place) said the roof may not be able to support a heavy snowfall because of the warped wood.
Who's right? Anyone else hear of this before?
New construction - warped wood-attic-1.jpg   New construction - warped wood-attic-2.jpg   New construction - warped wood-attic-3.jpg   New construction - warped wood-attic-4.jpg
NewOwner32 is offline   Reply With Quote
Old 09-05-2012, 05:38 PM   #2
kwikfishron's Avatar
Rewards Points: 172
This is one odd looking new construction roof. First, what you’re calling a beam is a stud to a purlin wall and an oddly constructed one at that. It looks like the studs were “short nailed” at the bottom which is why there twisting. Replacing #18 or any others is easy enough.
I’m more concerned with what I circled, it looks like a seat cut in the rafter where there shouldn’t be one, a major mistake and a guaranteed failure point. You’re inspector didn’t say anything about that, or am I just seeing things?
kwikfishron is online now   Reply With Quote
Old 09-05-2012, 07:56 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Good eye Ron and good question too!
tinner666 is offline   Reply With Quote
Old 09-06-2012, 04:11 PM   #4
Thanks for taking a look at the pictures.
The house is a modular home that was built off-site. The roof was laying flat when the home was shipped and lifted (on a hinge?) after the house was in place. I'll have to take a closer look the next time I'm in the house, but I think those cuts you circled may have something to do with the hinge system. Either way, the inspector never brought it up.
As for being "short nailed," are you saying that if the studs were longer - and tightly secured between the floor and the wall - the wood wouldn't have twisted?
Any idea what would have caused the wood to twist? The roof has been in place for approximately five months. I can't say for sure that the wood wasn't always bent, however.
Thanks!
Old 09-06-2012, 04:33 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,760
Scary...cutting into beams like that and nailing them together.
Old 09-06-2012, 05:06 PM   #6
Rewards Points: 172
Thanks!
By “short nailed” I mean not enough nails. For example if the bottom of #18 was nailed properly it would not have been able to move (twist) like that.
Those notches still concern me, maybe if you get back up there you can take a closer picture of one of them and measure how much “meat” of the rafter was left after they cut the notch.
Old 09-06-2012, 05:24 PM   #7
Newbie Bill
Rewards Points: 520
Wow Kwik, good eyes.
Guys, are these pre-engineered trusses? It looks like that stud wall was added after the fact. I would expect that if that wall was load bearing, it would have been factored (and built) into the truss system.
I think this photo better shows what Kwik was talking about.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 09-06-2012, 05:48 PM   #8
Haverhill Trade 1965
I worked at a modular house company and they build their trusses on site, (engineered), with a wall like that in the middle of each "box". It was only supposed to hold up the roof until it was unfolded and completely assembled. They were usually taken out but sometimes overlooked. They were mostly made of utility grade lumber and may have been twisted before they went in. You can contact the manufacturer and they can probably tell you what they are. If they are temporary, maybe not but, you could take them out. They make good kindling wood. If they are a support then for looks some, (or all and a top plate added), should be replaced.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
drtbk4ever (09-06-2012)
Old 09-06-2012, 07:00 PM   #9
Rewards Points: 172
Well that’s all great but it doesn’t explain the floating seat cuts.
I assume the gang nails above them are an engineered fix but why are they there in the first place.
Old 09-07-2012, 02:21 AM   #10
747
registered
747's Avatar
Rewards Points: 534
Need to ask the one guy. I don't remember his username. He was on contractor talk. He was a expert on modular builds.
747 is offline   Reply With Quote
Old 09-07-2012, 08:59 AM   #11
Rewards Points: 6,652
Those cuts, are so that the roof lays flat over that 1 1/2 pipe running along the wall in the back, while the transport the structure over the road.
Old 09-07-2012, 10:13 AM   #12
Rewards Points: 13,236
On the modulers I've worked on what your looking at is gussets not cuts.
Old 09-09-2012, 09:57 PM   #13
You may be right on Joe. If you take a good look at them they may even be the hinges the roof pivots up on.
Old 09-09-2012, 10:06 PM   #14
Rewards Points: 2,210
Not sure about replacing the twisted 'studs' looks like they are part of the overall truss system. They have metal plates holding them on at the top.
mae-ling is offline   Reply With Quote
Old 09-10-2012, 05:43 PM   #15
You never can tell with modular companies. They don't use hammers very often. I think they would install windows and cabinets with gang nail plates if it was faster.
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Vent Noise - Rubbing Wood; Seeking Advice steveo_1978 Plumbing 4 01-22-2010 11:26 PM
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 10:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
